Old 18th January 2020, 07:31 PM
Albert_Swafega Albert_Swafega is offline
Default Suspension Strut Compatability
Hi all,
i replaced my front left strut in the summer with a used 4H0616039AD.
in December the front right went, so i ordered another used 4H0616039AD off eBay.
once fitted, i found it fell overnight, checked all joints, no leak, so leg itself at fault.
the seller has sent me a replacement, but once unboxed i realised the part number was unfamiliar.
4H0616039J
after looking on ETKA it appears this is a SPORTS version and isn't compatible with 1BK running gear but for 2MA running gear.
the seller insists it's fine to fit, but i'm not too certain, i don't want one corner of the car stiffer/adjusting at a different rate from the others.
physically, it appears to be identical.
what are your thoughts??
2011 A8 Executive 3.0 TDI Quattro
Old 18th January 2020, 08:40 PM
homer simpson's Avatar
Sports will probably be stiffer. I wouldn't fit an incorrect part. I've looked on ETKA and AD is superseded with AK so would use either of these.
On a separate note, a 2011 A8 is showing a AP suffix for a 1BK vehicle?
Old 19th January 2020, 11:16 AM
That was my thought, might just ask to return both for a refund.
Just don't want to offend the seller, he's adamant it'll be fine.
Problem is, it's not a two minute job to fit either.
