Old 25th July 2016, 06:15 PM
Default S8 Inlet manifold flaps inspection
So some of you will be aware some of the first D3 S8's off the production line have had problems with inlet manifolds, there are plenty of stories of the flaps getting broken in the inlet manifold.
I too drive an early edition of the S8 so idle hands led me to have a look to see how things were today, thankfully mine are ok at present.
The following images and videos give you and idea of what to do to inspect them and how to go about it.
You will need to remove both air inlet ducts from the throttle bodies, like in the following two photo's
Separate the crankcase breather hose from the fine oil separator and remove the vacuum lines and disconnect the wiring from both throttle bodies.
There is a couple of screws that are not immediately obvious one being slightly obscured by a bracket that holds the wiring loom behind the engine and the other is the bracket that secures the oil separator to the throttle body bracket.
You can see now with the plenum removed the locations of the bolts.
Images of a good set of flaps
And an image of a broken set from the same perspective.
Once I established that mine were not hanging down like the above image I then recorded a video with the Output test selected for the flap change over, Cant remember exactly what it was called but you have to cycle through a set of sequential test until you get to it in Module 01 output tests.
See attachments for video.
ID:	13855   Click image for larger version
ID:	13856   Click image for larger version
ID:	13857   Click image for larger version
ID:	13858   Click image for larger version
ID:	13859   Click image for larger version
ID:	13860   Click image for larger version
ID:	13861   Click image for larger version
ID:	13862   Click image for larger version
ID:	13863   Click image for larger version
