Old 3rd August 2016, 04:56 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default VCDS Faults
Did a VCDS scan and apart from the normal handles and rear footwell faults I had some new ones that won't clear.
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 F
Component: Heizgeraet H07 0110
Revision: 0000000C Serial number: 00000009006406
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 1A3C5ED0D55678FB2B1-804E
2 Faults Found:
01336 - Company Data Bus for Comfort System
004 - No Signal/Communication
The Aux heater works as far as I can tell. Turn it on via HVAC controls and it kicks in and you feel the heat coming from the exhaust.
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H02 0120
Revision: PROD_01 Serial number: 00000000200813
Coding: 0000003
Shop #: WSC 02313 785 00200
VCID: 2C5088088FC2F64B49D-8078
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 76
Mileage: 283835 km
Time Indication: 0
Date: 2016.08.03
Time: 16:03:45
As far as I can see its coded correctly. Right hand drive, with leather and a diesel.
Plus 1 for the microphone.
It was set to 03 and I added the 1, reset and rescan. same fault code.
If anyone got any ideas, that wold be great.
I'll have a better look this weekend.
[center]
06 3.0TDI Quattro:
Options:
