Old 15th August 2016, 08:38 PM
SilverS8 SilverS8 is offline
Default Those beloved fault codes again; 17972,17966,17521
Good evening
Just back from a 1000 mile trip, and even though the car felt mostly ok, I felt it lacked some power now and then
No lights in the dash but the fault codes when running VCDS below.
3 Faults Found:
17972 - Throttle Actuator (J338)
P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
17966 - Throttle Actuator (G186)
P1558 - 35-10 - Electrical Malfunction - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1
P1113 - 35-10 - Internal Resistance too High - Intermittent
Readiness: 0000 0000
Just to mention that my MAF is only a few months old (OEM PART)
17972 : I have done Throttle adaptation without any luck. I did look at my TB readings and find them a bit odd.
TV Sensor 1 16% (should be between 0-10 it says)
TV Sensor 1 at WOT is "only" 85%
Is my TB about to go on a permanent vacation?
17966 Same as the above? (found nothing on the forum for this code)
17521: Broken O2 pre-cat sensor? UK Driver or passenger side?
Any way to read meas.block to see if one is failing?
All tips apprecaiated
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 15th August 2016, 09:39 PM
B1S1 is UK driver side. Somewhere in the technical dump for the D2s, there are tests you can perform. If you also use the Search facility for O2 sensors, you'll find lots of other information as well relating to them.
Old 16th August 2016, 12:18 AM
From my dodgy idle thread:
Originally Posted by Me
Reading up a bit more about the O2 sensors in ElsaWin I found the procedure to re-learn the adaptation values (basic settings 32 & 33), and also how to turn them on and off (basic settings 99).
Measuring block 1 shows the values for each bank:
Might be worth a scan of the wiring diagrams to see if the TB and B1S1 O2 sensor share any wiring. Bad ground maybe?
Old 18th August 2016, 06:38 PM
Now we are down to 2 fault codes. 17966 has misteriously dissapeared..
2 Faults Found:
Snipped a few shots from VCDS.
Lambda values seems fine to me?
Is my voltage to low?
ID:	13991   Click image for larger version
ID:	13992   Click image for larger version
ID:	13993   Click image for larger version
ID:	13994   Click image for larger version
ID:	13995   Click image for larger version
ID:	13996   Click image for larger version
ID:	13997   Click image for larger version
2000 Silver S8
Old 18th August 2016, 06:42 PM
How often/when do you clear the fault codes and how soon/when do they reappear?
Old 19th August 2016, 04:00 AM
are your manifold flaps operating ok? have you checked they are not seized and or the linkages are working correctly and not broken on the actuators?
Old 19th August 2016, 05:22 AM
The lambda error is for the heating element, so it takes a minute or 2 longer for it to heat up and start working. I would not worry about it at all.
Old 19th August 2016, 05:13 PM
Hi.
Flaps are working as the should.
Nor sure how quickly the codes return. Was unable to get them to return by idling/reving it in the driveway last night.
On another trip this weekend with the family. so i'm gonna check tonight when we arrive at our destination if the codes are back
I do see that the rear bumper og trunk is "covered" in soot..(not from oil)
Never ever seen this before.
2000 Silver S8
