Old 11th September 2016, 01:17 PM
Default New windscreen-1, Auto lights-0
Hello all
I had a new windscreen fitted, all good, however now when lights are set to auto main beam is on all the time, quite annoying as the satnav stays dark.
I am assuming there is a light sensor in the rear view mirror assembly that has been fiddled with somehow?
Also, does the battery need to be disconnected for a windscreen replacement? I noted the time was incorrect and a few other settings were different when I picked the car up and wondered if that had effected the auto light settings?
Thanks.
Old 11th September 2016, 03:14 PM
Turbo Tony's Avatar
Double check the light/rain sensor is mounted tight up to the screen and that there's no debris between the sensor and the windscreen. It's mounted above the rear view mirror.
Storytellers Villa Orlando
2008 Audi S8
