Old 23rd December 2016, 10:49 AM
North2007 North2007 is offline
Default Done and To Do/ Wish List
Done
Off side Turbo, actuator, & oil seal replaced
Fuel flap actuator
Upper and lower front suspension arms x 8
Repaired CV outer boot
Battery replaced & coded
Boot soft close motor replaced
Drivers door card replaced
Removed dark tint
4 x alloys refurbished
4 x tyres replaced
Wheel alignment checked
Front & rear pads replaced
EPB repaired/ replaced (both sides, complete with new calliper seals)
Suspension level sensor replaced front near side
MMI (sticking button) removed & cleaned (coke liquid!)
Interior LED lights fitted
LED side light bulbs replaced with error free bulbs.
Full service (air/ fuel and oil filters, 9l oil)
Front wheel bearing replaced
Front passenger seat lower motor jammed (released)
Horns replaced
Near side bonnet catch repaired
Drivers side intercool pipe split - repaired
Brake discs (lip removed), callipers, dust plate painted heat resistance paint
New alloy wheel centres
2 x number plates
Front near side wing rear foam seal
Inlet manifold removed and cleaned x 2
Brake switch repaired
Replaced rear centre arm rest
Injectors x8 cleaner added
VCDS professional software and lead
Water channel cleaner - anti freeze/ coolant added.
To Do
Paint rear pass quarter, front and rear bumper, and drivers door
Decrome some exterior trim
Replace auto dip/ heated drivers mirror glass
Fit boot lip spoiler (low profile)
Replace rear lights LED spec x 4
Power chip +70bhp - 340bhp
Fit removal tow bar and electrics
Repair drivers seat boaster leather damage/ upgrade full leather
Fit OEM mud flaps x 4
Fit OEM mats x 4
Fit engine under tray
Replace inner front guards x 2
Fit rear near side jack point
Fit 10mm wheel spacers complete with extended bolts x 20 (alloys ET40)
Buy OEM Jack
Fit custom suspension level link arms x 4
Order spare key
Fit OEM MMI iPhone interface
Upgrade MMI
Fit Rear OEM ICE (Headrests)
Fit OEM wheels / winter tyres R18
Replace front grills with homemade custom honeycomb x 4
Fit homemade front wing air vents (design TBC)
Replace front pass seat rely module
K&N Air Filters x 2
Stainless Steel Exhaust
OEM roof bars
Replace bonnet release cable
Brake fluid change
AC seals replaced and re-gas.
Rear window replace (heating element defective)
OEM manual
Workshop manual
Interior button repair paint
Shark fin roof
S8 Door mirror covers
Auto retract door mirrors module on key lock
9 x faults heater related, motor flaps etc!
2003, A8 D3 4.0 TDI
Old 23rd December 2016, 11:30 AM
That's quite the list.
Look forward to updates as you go
