Hi just done a full scan for the first time. What does it all mean and do I need to do anything?
I notice its throwing up a fault code re the EGR which has been mapped out. Can I change the config to lose this? Tuesday,31,January,2017,13:07:06:45075 VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64 VCDS Version: 17.1.2.0 (x64) Data version: 20170127 DS267.1 www.Ross-Tech.com VIN: WAUZZZ4E77N017525 License Plate: Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 18 19 1D 1E 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77 VIN: WAUZZZ4E77N017525 Mileage: 283630km-176239miles 00-Steering Angle Sensor -- Status: Cannot be reached 1100 01-Engine -- Status: Cannot be reached 1100 02-Auto Trans -- Status: Cannot be reached 1100 03-ABS Brakes -- Status: Cannot be reached 1100 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: Cannot be reached 1100 31-Engine other -- Status: Cannot be reached 1100 15-Airbags -- Status: Cannot be reached 1100 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 1D-Driver Ident. -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 34-Level Control -- Status: Malfunction 1110 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Cannot be reached 1100 55-Headlight Range -- Status: Cannot be reached 1100 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Malfunction 0010 67-Voice Control -- Status: OK 0000 6C-Back-up Cam. -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E1 910 409 B HW: 4E1 907 409 A Component: 4.2L V8TDI G000AGMª0010 Revision: --H04--- Serial number: AUX3Z0G1316673 Coding: 0011773 Shop #: WSC 02313 785 00200 VCID: 2345C323E265EB59DE-8076 No fault code found. Readiness: 0 0 1 X 1 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 S HW: 09E 927 156 B Component: AG6 09E 4,2 TDI RdW 0010 Revision: --H01--- Serial number: 0102515 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 3365336352857BD92E-8066 2 Faults Found: 049408 - No Communication with Engine Control Module (SAE ECM/PCM) U0100 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 281776 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:14 Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min (no units): 30.0 (no units): 25.0 Temperature: 57.0°C T.B. Angle: 60.0° 006273 - Powertrain Data Bus: Missing Message P1881 - 000 - Acceleration Request - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 281776 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:14 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H46 0510 Coding: 0008557 Shop #: WSC 02313 000 00000 VCID: 224BC627FD7FE251D5-8076 2 Faults Found: 02083 - Message for Delay Request 004 - No Signal/Communication - Intermittent 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0G1316673 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BFA4CFEBA37881FB-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 2 Faults Found: 00955 - Key 1 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 0 Reset counter: 18 Mileage: 281824 km Time Indication: 0 Date: 2017.01.09 Time: 10:25:10 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 0 Reset counter: 18 Mileage: 281824 km Time Indication: 0 Date: 2017.01.09 Time: 10:25:10 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 02313 785 00200 VCID: 2447C03FE76BEC61A7-8070 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300BC077579000 Coding: 0000002 Shop #: WSC 00000 785 00200 VCID: 3A7B1E4775EF8A91ED-806E Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0040 Subsystem 2 - Serial number: 00000000031782 Subsystem 3 - Serial number: 0122.02.070000000100010002ÿ Subsystem 4 - Serial number: 010002ÿ 1 Fault Found: 02244 - Button in Control Head is Stuck 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 2 Reset counter: 40 Mileage: 282072 km Time Indication: 0 Date: 2017.01.13 Time: 09:19:53 Freeze Frame: Bin. Bits: 01000000 Bin. Bits: 0000000 Bin. Bits: 001 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000115342 Coding: 0022625 Shop #: WSC 02311 785 00200 VCID: 1C37F8DFDF1BD4A11F-8048 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q Component: ILM Fahrer H15 0230 Coding: 0143121 Shop #: WSC 02313 785 00200 VCID: 36630A7741F76EF109-8062 Subsystem 1 - Part No: 4E2 910 113 C Component: Wischer WWS D3 H60 0440 Coding: 00000037 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH13 0090 Coding: 00139548 Shop #: WSC 02313 1 Fault Found: 01520 - Rain and Light Recognition Sensor (G397) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 39 Mileage: 283066 km Time Indication: 0 Date: 2017.01.24 Time: 17:19:46 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 E HW: 4E0 035 110 A Component: MP3-Changer H44 0390 Revision: 00044000 Serial number: AUZ5ZBG3169617 Shop #: WSC 00000 000 00000 VCID: 1A3BFEC7D52FAA910D-804E No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: None Part No SW: 4E0 910 563 C HW: 4E0 035 563 Component: DAB-Tuner H41 0830 Revision: 00000001 Serial number: KE1276U8200307 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2447C03FE76BEC61A7-8070 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E1 910 409 B HW: 4E1 907 409 A Component: 4.2L V8TDI G000AGSª0010 Revision: --H04--- Serial number: AUX3Z0G1316673 Coding: 0011773 Shop #: WSC 02313 785 00200 VCID: 2345C323E265EB59DE-8076 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H14 4210 Revision: 91H14421 Serial number: 0037P0G08VUY Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 275DD733965D077982-8072 Subsystem 1 - Serial number: 63328RB40212C3097 Subsystem 2 - Serial number: 63428RB40212BAC8P Subsystem 3 - Serial number: 63528RB40212986FN Subsystem 4 - Serial number: 63628RB402129BDFY Subsystem 5 - Serial number: 63729RB4021BB850L Subsystem 6 - Serial number: 63829RB4021BB820J No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H14 0040 Coding: 0112141 Shop #: WSC 02311 785 00200 VCID: 65C19D3BACD1D56970-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 951 B HW: 4E0 920 951 B Component: KOMBIINSTR. VDO H82 0530 Revision: D05 Serial number: AUDID3G2000909 Coding: 0048413 Shop #: WSC 00508 067 57207 VCID: 2447C03FE76BEC61A7-8070 1 Fault Found: 16346 - Control Module - ROM Error 014 - Defective Freeze Frame: Fault Status: 00000011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 70498 km Time Indication: 0 Date: 2010.06.15 Time: 08:56:29 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 G Component: Heizgeraet H08 0140 Revision: 0000000C Serial number: 00000009013887 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 1A3BFEC7D52FAA910D-804E 1 Fault Found: 00664 - Fuel gauge 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.clb Part No SW: 4L0 910 468 HW: 4L0 907 468 Component: J533__Gateway H06 0040 Revision: 00H06000 Serial number: 0900B072258011 Coding: F5DDDFFF707E1E Shop #: WSC 02313 785 00200 VCID: 6CD7E81F4F3BE4212F-8038 2 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 36 Mileage: 281776 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:14 01342 - Engine Control Module 2 (Slave 1) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 36 Mileage: 281776 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:14 ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 A HW: 4E2 905 218 B Component: FPI_1 H01 0020 Revision: 01000102 Serial number: 29012007145348 Shop #: WSC 00000 000 00000 VCID: 1F4DCFD3CE0DCFB9FA-804A 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 14 Reset counter: 47 Mileage: 283632 km Time Indication: 0 Date: 2017.01.31 Time: 12:57:02 ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H15 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00000 000 00000 VCID: 2B552B034AB5231966-807E No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 J HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 6310 Coding: 0015510 Shop #: WSC 30026 002 1048576 VCID: 2A5B2E07854F3A119D-807E 2 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 36 Mileage: 281776 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:14 01400 - Suspension Level Control 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 36 Mileage: 281776 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:14 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063342 Shop #: WSC 02313 785 00200 VCID: 2447C03FE76BEC61A7-8070 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 887 T HW: 4E0 919 887 L Component: MNS ECE H48 1030 Revision: 00000000 Serial number: 364CZ077643875 Shop #: WSC 00751 210 83996 VCID: 3E73125769C7A6B1D1-806A No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H05 0090 Serial number: 00000700900065 Coding: 0036048 Shop #: WSC 02313 785 00200 VCID: 1D31F5DBC401DDA9E8-8048 1 Fault Found: 01370 - Alarm triggered by Interior Monitoring 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 16 Mileage: 262136 km Time Indication: 0 Date: 2017.01.09 Time: 10:24:00 Freeze Frame: Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 D Component: Türsteuer.FS BRM005 0180 Coding: 0032622 Shop #: WSC 02313 785 00200 VCID: 204FCC2FF373F041C3-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 C HW: 4E0 907 289 C Component: Komfortgeraet H09 0020 Revision: 00200009 Serial number: W040702220086 Coding: 0004861 Shop #: WSC 02313 785 00200 VCID: 2959D10B8049310994-807C Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H05 0020 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 36 Mileage: 281776 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:15 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 R HW: 4E0 035 223 G Component: DSP-High D3 H03 0120 Revision: PROD_01 Serial number: 00000000005099 Coding: 0000023 Shop #: WSC 02313 785 00200 VCID: 2C57281F8FBB24216F-8078 1 Fault Found: 00871 - Bass Speaker Front Right (R23) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00111011 Fault Priority: 5 Fault Frequency: 2 Reset counter: 37 Mileage: 282788 km Time Indication: 0 Date: 2017.01.23 Time: 13:28:44 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000106069 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E33F2D7C907C6B1F1-804A 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 37 Mileage: 262136 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 D Component: Türsteuer.BF BRM005 0180 Coding: 0032622 Shop #: WSC 02313 785 00200 VCID: 204FCC2FF373F041C3-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0001031 Shop #: WSC 56998 001 1048576 VCID: 204FCC2FF373F041C3-8074 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 2 Reset counter: 36 Mileage: 281776 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:14 Freeze Frame: Voltage: 11.08 V Count: 241 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 23123 823 51872 VCID: 2959D10B8049310994-807C Subsystem 1 - Part No: 4F0 941 329 B Component: AFS-Modul links H02 0020 Subsystem 2 - Part No: 4F0 941 329 B Component: AFS-Modul rechtsH02 0020 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 37 Mileage: 281784 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:14 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 S Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 396CY077560862 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 3169396BA89949C95C-8064 No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 E HW: 4E0 919 148 Component: R0078 TVhybridT 0470 Revision: R0H06000 Serial number: 76300800253501 Coding: 0000003 Shop #: WSC 02313 785 00200 VCID: 2541DD3BEC511569B0-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000002113 Shop #: WSC 00586 586 91374 VCID: 204FCC2FF373F041C3-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 2702230006 Coding: 344530393135313035412056413032373032323330303036 Shop #: WSC 00000 128 00289 3 Faults Found: 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 255 Mileage: 280180 km Time Indication: 0 Date: 2016.12.01 Time: 05:15:13 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 255 Mileage: 280180 km Time Indication: 0 Date: 2016.12.01 Time: 05:15:13 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 37 Mileage: 281776 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:14 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: Türsteuer.HL BRM005 0180 Coding: 0032622 Shop #: WSC 02313 785 00200 VCID: 1E33F2D7C907C6B1F1-804A No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 A HW: 4F0 907 273 A Component: Reifendruck 3 H05 Revision: 00050340 Serial number: 00000700049983 Coding: 0202127 Shop #: WSC 65762 132 00001 VCID: 204FCC2FF373F041C3-8074 3 Faults Found: 01299 - Diagnostic Interface for Data Bus (J533) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 2 Reset counter: 37 Mileage: 281776 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:24 Freeze Frame: (no units): 0.0 Voltage: 0.00 V (no units): 27.0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. 01477 - System Switched Off 000 - - Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 2 Reset counter: 37 Mileage: 281776 km Time Indication: 0 Date: 2017.01.07 Time: 11:54:24 01521 - Sensor for Tire Pressure 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 158 Mileage: 278711 km Time Indication: 0 Date: 2016.11.03 Time: 17:28:19 Freeze Frame: (no units): 98.0 Temperature: 9.0°C Error Code: 0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000702230220 Shop #: WSC 12336 024 394758 VCID: 36630A7741F76EF109-8062 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4E0-910-441.clb Part No SW: 4E0 910 441 HW: 4L0 907 441 A Component: J772__Rearview 0050 Revision: --H12--- Serial number: 525PA8-J7210C8 Coding: 1020402 Shop #: WSC 02313 785 00200 VCID: 5CB7B8DF9F9B94A1DF-8008 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 D Component: Türsteuer.HR BRM005 0180 Coding: 0032622 Shop #: WSC 02313 785 00200 VCID: 1E33F2D7C907C6B1F1-804A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08730703109751 Coding: 0321008 Shop #: WSC 02313 785 00200 VCID: 2345C323E265EB59DE-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 M HW: 4E0 862 335 Component: Handyvorb2 H20 1130 Revision: 00000000 Serial number: 00000005154976 Coding: 0010900 Shop #: WSC 00508 210 88175 VCID: 2C57281F8FBB24216F-8078 No fault code found. End-------------------------(Elapsed Time: 04:18)--------------------------
2007 4.2tdi Quattro Sport. Valcona black leather, Extended leather, Sports comfort Seats, Fr&R Heated seats, 20" wheels, BOSE, Media Interface, TVIM, DAB, CD changer, Bluetooth, Reversing Camera, Auto dim mirrors, Blinds, Soft close doors, Elec Boot, Keyless entry, Finger print read, TPMS, BI Xenon Active lights, LED indicators, LED puddlelights from door mirror when door closed. |
Seems to be a lot of 'no comms' between modules. Was the battery every flat?
Now you have a log I would erase and re-scan, it's the ones that come back you need to worry about |
I'm also wondering if the CAN Gateway has some kind of interruption in it, hence all the "no communication" comments. . . .hmmm
Thanks for your replies
This was after the 1st scan and then a clear. Not sure that worked though. Is there a procedure with the ignition after hitting clear? The modules spoke fine, if you look at the list below, I was just a little slow getting the ignition on.... Can anyone help with the EGR coding?
Ok. Will do. Do I need to reset the system each time I clear?
Ie turn the ignition on and off?
I would suggest that you need to start and run the car before taking another scan. I am not too sure how this works but it seems to me that even if you clear the fault codes it still stores the fault condition unless its been through a "self check" on next being used and hence raises a fault code. I may be talking bollox here but I have found that I have needed to start/run the car to stop the DTC appearing again. Someone with vastly more knowledge may well be along to put me right.
no you can leave the cable and laptop connected, you are just sending an instruction to the modules to clear any fault codes but some may need you to drive the car before some faults return dependant on what the issue is
I completely agree with the comment saying you should enter each control module and clear individually. I had a persistent bug and it cleared only when I cleared that module alone.
Post your results when you're done and hopefully there isn't anything left to do. ![]() |
I've cleaned up your VCDS log a bit.
Removed all the no fault codes and removed some of the less needed information. ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl 2 Faults Found: 049408 - No Communication with Engine Control Module (SAE ECM/PCM) U0100 - 000 - - Intermittent 006273 - Powertrain Data Bus: Missing Message P1881 - 000 - Acceleration Request - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl 2 Faults Found: 02083 - Message for Delay Request 004 - No Signal/Communication - Intermittent 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl 2 Faults Found: 00955 - Key 1 002 - Lower Limit Exceeded - Intermittent 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Flat battery at some point. Clear the code and try again ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl 1 Fault Found: 02244 - Button in Control Head is Stuck 000 - - - Intermittent Button in the roof panel stuck. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl 1 Fault Found: 01520 - Rain and Light Recognition Sensor (G397) 002 - Lower Limit Exceeded - Intermittent possibly due to flat battery. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl 1 Fault Found: 16346 - Control Module - ROM Error What it says. Possible a fault with the cluster EPROM ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None 1 Fault Found: 00664 - Fuel gauge 002 - Lower Limit Exceeded - Intermittent Low fuel and it stopped the aux heater kicking in ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.clb 2 Faults Found: 01314 - Engine Control Module 01342 - Engine Control Module 2 (Slave 1) 004 - No Signal/Communication - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Another flat battery issue ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl 2 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent 01400 - Suspension Level Control 001 - Upper Limit Exceeded - Intermittent Engine comms issue. Not sure on the other. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl 1 Fault Found: 01370 - Alarm triggered by Interior Monitoring 000 - - - Intermittent Alarm went off ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl 1 Fault Found: 00871 - Bass Speaker Front Right (R23) 011 - Open Circuit - Intermittent As it says. possible fault with base speaker, not pluged in. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl 3 Faults Found: 02272 - Quiescent Current Stage 1 000 - - - Intermittent 02273 - Quiescent Current Stage 2 000 - - - Intermittent 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent falt batter and that engine ECU comms again ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl 3 Faults Found: 01299 - Diagnostic Interface for Data Bus (J533) 013 - Check DTC Memory - Intermittent 01477 - System Switched Off 000 - - 01521 - Sensor for Tire Pressure 004 - No Signal/Communication - MIL ON no comms as above but possible a fault with TPMS module not plugged in.
