Hi all... hoping to get some advice from you folks about the MMI set up on my A8 D3. It currently has the most up to date software version but it seems as though it wasn't set up properly as the mpg readings seem to be in litres and the car configuration appears to be left hand drive. I can access the green hidden menu so wondering if there is anything I can do in there to change this? Or do I need the VCDS? Cheers
Current: MY57 Audi A8 3.0 TDI Quattro SE, Silver, Black Comfort Heated Leather, MMI High 2G, Bluetooth, Nav, Voice Control, AMI, Rear Camera, 6CD, 20 inch 9-spoke alloys [in Black], Folding Mirrors, 3-spoke S Line steering wheel + mods to come ![]() Last edited by speed_demon1978; 7th February 2017 at 09:44 PM. |
The mpg will be VCDS. Cluster possibly set some where in Europe.
When you say left hand drive, what do mean? In the green menu, car diag, look for linkslenker, it should be unlocked.
Current: MY57 Audi A8 3.0 TDI Quattro SE, Silver, Black Comfort Heated Leather, MMI High 2G, Bluetooth, Nav, Voice Control, AMI, Rear Camera, 6CD, 20 inch 9-spoke alloys [in Black], Folding Mirrors, 3-spoke S Line steering wheel + mods to come ![]() |
The LHD settings from what I know will affect things like AC when adjusting driver's side it will say passenger.
You can't have MPGs in km, it will either say xx mpg or xx l/km (l/100km). If you open left door it will show left door etc. You can change measuring unit within MMI if you think the setting is incorrect, Car the Settings or Car, Setuo and settings, not hard to find.
1) Left / Right setting[s]. Your conditions probably reflect someone messing with the car ECUs in the past. The Driver and Passenger door ECUs are identical but coded differently. Unfortunately I can't find any coding explanations for the ECUs but I have ECU HW 4E0 959 760 in both doors and mine are coded "3670112" Passenger - Left - ECU 06 and "3670126" Driver - Right - ECU 36. 2) Miles/Km As Marcin indicates, this is relatively simple, as it is a selection off the MMI menu somewhere for the units to be used for the car. HOWEVER, if you have a fingerprint reader, Mi/km is one of the settings that is retained for each user. [As there are 4 users with fingerprint reader, this make 5 variations available, as there is also a setting that is used if the driver is not identified].
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
The door ECU's are specific to their location: Driver (0x42) module J386 hw 4E2 907 289 Passenger (0x52) module J387 hw 4E2 959 801 Coding across the driver and passenger doors are equal and due to the different hardware they can not be swapped by coding alone and will always be driver and passenger. Also, because we're RHD our door modules start with a 4E2... As to the front seats, coding is different between the driver and passenger - but this does not tell the control module it is Passenger (0x06) or Driver (0x36), yet both are an identical J136. There is a +12v 'jumper', PIN A30, on the Passenger (0x06) module, it is absent on the drivers (0x36) module. This is hard wired at the factory.
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 13th February 2017 at 01:55 PM. |
![]() Tried looking for the settings in the main options as well as hidden green menu to no avail though for changing mpg which currently reads as xx l/km (l/100km.
Hi Matt - do you mean a pic of my driver door open and then the centre instrument cluster image showing the passenger door open instead? I did go through the 'green' menu and found somewhere it said the vehicle had a LHD set-up from what I could decipher in German in one of the menu options!
Will try and take some pics later today. ![]()
