Old 27th January 2009, 04:08 PM
Default CV Boot replacement
Had a blow out and grease all around the inside of the wheel.
Can get Bilstien gaiters for £15, no name for £5. Anyone used generic gaiters?
Old 27th January 2009, 04:37 PM
Never used them on the '8, but have on previous motors and not noticed any difference, but then again, probably never had them long enough afterwards. I'd think you'd still get plenty of life.
But for a tenner, is it worth the chance?
Old 27th January 2009, 10:26 PM
Mkoneman's Avatar
Mkoneman Mkoneman is offline
£30 for the kit from audi.
boot, clips, greese, bolt
im a sucker for oem parts on my car
www.facebook.com/obdworks
full genuine ross-tech vcds
full genuine vag- tacho
Old 28th January 2009, 10:07 AM
harpersimon
Guest
Posts: n/a
is there a prodecure for doing these?
Old 28th January 2009, 12:52 PM
Hmmmmm Check the Sticky?
Old 30th January 2009, 08:54 AM
harpersimon
Guest
Posts: n/a
Er.. I did - and I don't see anything that says Gaiter replacement ?-Plenty of stuff about drive shafts and axles but can't see where it tells you how to remove the gaiter when one is split - assuming its part of taking the drive shaft out but don't see that comprehensively described either!?
** Update** - Found a CV replacement post by using the groovy Google search - which took me here
Technically this post is in the wrong section - should be moved to Axles and Steering with the other CV stuff?
Old 30th January 2009, 09:34 AM
Zip's Avatar
Zip Zip is offline
Exclamation Had another quote...
...from my local Mr Clutch (!!) at £60 each fitted. That is using silicon boots which are guaranteed not to perish.
May take them up on the offer....Audi wanted over £400!!
Zip
Old 30th January 2009, 10:08 AM
harpersimon
Guest
Posts: n/a
£400!! As above the parts are only £30 from Audi!! How much is Stealer Labour rates these days. Criminals
Old 30th January 2009, 02:43 PM
[arnie voice]The Axel's, Suspension and Steering Sticky under CV Joints?
However, nice find, added to sticky[/arnie voice]
Old 30th January 2009, 05:14 PM
Mkoneman's Avatar
thats criminal, its a 2 hour job max
id say if your thinking of doing it and not taken the upper control arms out before then get a new long bolt that holds them in they can become damaged trying to get them out, or take the wheel off a day before and spray them with a releasing fluid such as wurth rost off
