Old 28th July 2017, 12:14 AM
karlcossy karlcossy is offline
Default cp removal
looking for cp removal in and around Leicestershire Warwickshire area please
will traval within reason as don't want to be paying over 200 plus at audi stealer again just for dash change
Old 28th July 2017, 06:02 AM
Ring round your local indy specialists to see who has ODIS - I know one local to me who charges £20 for online hookup, plus 0.3hr for adapting the software and coding in a retrofit RVC so total of £45
Old 28th July 2017, 05:43 PM
I have had it done twice. Once by the dealer when it was in for the MOT they did the MP3 drive for about £25.. A few years later, they refused to do it for a used cluster - took it down south to be done by an indy who had the Audi VAS system. It took him 5 minutes and does it to any module that is in CP, they can't choose specific ones.
If it happened again, I would probably go to the dealer and say it happened after a flat battery and the AA said take it to the dealer to remove CP.
The way they remove it is by reading fauly codes, then Guided Fault Finding of the codes it sets which ends in clicking Remove CP, it then scans every module clearing the CP. It is quite easy and they shouldn't charge much, especially combined with an MOT or similar.
Old 29th July 2017, 12:09 AM
H-M3 H-M3 is offline
would he cover london as i need to change my cluster?
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 29th July 2017, 01:32 PM
You'd obviously need to take the car to them - they're called Camspec and they're on Manor Royal, a few doors up from DS Autowerks (David is a member on here and is well recommended but doesn't yet have ODIS).
Old 29th July 2017, 03:17 PM
homer simpson's Avatar
What is required? ODIS and any online connection or an account with Audi Germany?
Old 30th July 2017, 08:48 AM
I believe you buy the cable and software to connect for about £1k then there's options around pay per use or pay per day depending on likely throughput of customers
Old 3rd August 2017, 12:04 AM
cheers guys interior nearly finished just one rear seat to get working and connect up audi dvd system
been a right nightmare doing this and not helped one bit by the audi breaker I got it all from
still got acc to do next had that kit for months and not done yet still need a gateway
