Old 5th October 2017, 03:05 PM
maniac8082 maniac8082 is offline
Default same codes keep reappearing
hi i have a 2005 Audi A8L , i have the following codes: P0341,P0300,P0301,P0302,P0303,P0304, and P0106 I've changed the cam sensor, put new spark plugs and coils and erased the codes but they keep coming back has anyone had this problem or know of a solution?
2005 Audi A 8L 4.2 petrol
Old 5th October 2017, 03:13 PM
Have you got access to genuine VCDS cable??
If so can you post a full log?
Check possible causes/solution and special notes in each link for each code.
P0341
http://wiki.ross-tech.com/wiki/index...5/P0341/000833
P0300
http://wiki.ross-tech.com/wiki/index...4/P0300/000768
P0301 / P0302 / P0303 / P0304 (cyl 1, cyl 2, cyl 3, cyl 4)
http://wiki.ross-tech.com/wiki/index...5/P0301/000769
P0106
http://wiki.ross-tech.com/wiki/index...0/P0106/000262
Old 5th October 2017, 06:22 PM
im not sure what genuine is but this is what im using CAN OBD II item 98568
Old 9th October 2017, 06:15 PM
Have you bought the car with this fault on it ? Has the car been ok at some point?
Have you had any work done on it recently.....let me have a pop at it ...... cambelt job by any chance ??
Old 11th October 2017, 06:20 AM
i bought the car from an auction it had front end damage i put in a radiator,fan,condenserand hood
Old 11th October 2017, 06:37 PM
From them codes I think you need to strip it down and check cam timing
Old 11th October 2017, 11:17 PM
ok thank u
