looking into larger rear discs im finding several sizes are available.
looks like 335mm are the biggest ! so i need to know the following please can i use the same caliper ? i know i have to buy the apropriate caliper carriers too cheers all
Looking for the Holy Grail Audi .. 2018 VW Caravelle Executive T6 2010 A6-C6 3.0tdi LeMans Quattro |
Yes, the caliper is the same from 280-335mm. Just the carrier changes.
Will not recommend to increase the size in the rear if you are not doing the same in the front, or else you will upset the brake bias.
2006 Audi A8 3.0 TDI Quattro Sport A8 W12/S8 Brakes front and rear (385mm/335mm) Focal and JBL speakers, Helix amps S8 anti-roll bars front and rear Complete rear LED taillight Xenon fog lights All interior LED S8 rims 9x20" Stage II tune S8 Grill |
Already got S8 fronts on ![]() ![]()
Oh ok, then I highly recommend to mount the same in the rear, because now you've already upset the brake bias. I did the S8/W12 brakes on mine a few years ago and did the fronts first and the rear the day after. In between I had a test drive and the balance of the brakes was horrible! The car nose dived heavily under braking and if I used brakes in corners, it under-steered a lot. After finishing both the front and the rear, the brake balance is perfect.
Tip, also change to S8 anti sway bars. ![]()
can anyone confirm these part numbers for a pair of 335mm rear caliper carriers for the D3
3D0 615 426 D 3DO 615 425 D left & right thanks
The numbers you have is for the dust shield, that you need to replace too. The old ones won't fit with the bigger disc.
For the carriers: Left: 4E0615375D (Wrong number) Right: 4E0615376D (Wrong number) New ones below.
2006 Audi A8 3.0 TDI Quattro Sport A8 W12/S8 Brakes front and rear (385mm/335mm) Focal and JBL speakers, Helix amps S8 anti-roll bars front and rear Complete rear LED taillight Xenon fog lights All interior LED S8 rims 9x20" Stage II tune S8 Grill Last edited by NightOwl; 25th April 2020 at 08:18 AM. |
3D0615426D + 3D0615425D i think is correct also confirmed by TPS and A8 parts also anybody had experience with the following? https://www.ebay.co.uk/itm/222662699872
Looking for the Holy Grail Audi .. 2018 VW Caravelle Executive T6 2010 A6-C6 3.0tdi LeMans Quattro Last edited by roberto; 25th April 2020 at 07:50 AM. |
Ops, my number over is wrong!
New numbers for the carriers: Left: 4E0615425A Right: 4E0615426A Look at attached pic. ![]()
2006 Audi A8 3.0 TDI Quattro Sport A8 W12/S8 Brakes front and rear (385mm/335mm) Focal and JBL speakers, Helix amps S8 anti-roll bars front and rear Complete rear LED taillight Xenon fog lights All interior LED S8 rims 9x20" Stage II tune S8 Grill Last edited by NightOwl; 25th April 2020 at 08:16 AM. |
