Old 22nd July 2014, 10:36 AM
Lyons Lyons is offline
Default Dashcam
Has anyone got a dashcam installed in their D3?
If so, which one have you got and how is it wired in?
Old 22nd July 2014, 10:54 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I have a blackvue DR380g.
Wired it in to the head lining unit at the front.
[center]
06 3.0TDI Quattro:
Options:
Old 22nd July 2014, 10:55 AM
ScottD3's Avatar
Its all installed and working fine.
I used this little port off the heads up controls.
Used the proper Audi Plug and cables, then connected them to a random mobile phone charging cable I had which fitted the Camera.
Put it all back together and it ended up like this.
All in and working.
[center]
06 3.0TDI Quattro:
Options:
Old 22nd July 2014, 11:04 AM
That looks brilliant! Absolutely ideal.
Was it handy enough done? So there only 2 wires needed? Do you know the part numbers of the Audi bits?
Then just lopped off the charger cigarette lighter plug and connected to the 2 Audi wires?
Old 22nd July 2014, 11:07 AM
ScottD3's Avatar
You can see on the pic which pins you needs.
Its 4 and 2. going right to left looking at the pic.
I used this plug.
8k0973754
And this cable
000979009E
I was lucky with the Blackvue camera that it takes a 12v feed.
Some cameras might be a 5v feed. so you can't cut the plug off and wire it in.
Make sure what voltage it needs first.
[center]
06 3.0TDI Quattro:
Options:
Old 22nd July 2014, 11:12 AM
Cheers. So the left wire in photo 2 is pin 2 and the right wire is pin 4? What are they both?
I'm after a cheaper camera as I intend to get 1 for the wifes Tiguan too, but the installation is perfect. Something else for the to do list!
Old 22nd July 2014, 11:20 AM
ScottD3's Avatar
Left is pin 4, that's earth.
right is pin 2, that's live.
Come say hello.
http://dashcamowners.com/
some nice cheap cams around.
[center]
06 3.0TDI Quattro:
Options:
Old 22nd July 2014, 11:25 AM
Last question, does the part number for cable come as a single or a pair of wires?
Old 22nd July 2014, 11:42 AM
ScottD3's Avatar
Its a double ended cable.
So you only need the one.
[center]
06 3.0TDI Quattro:
Options:
Old 7th August 2014, 01:10 PM
I got a camera a year ago. It was £17 and pretty rubbish and was a fake of a decent model.
Just changed it for a G1W a couple of weeks ago and thrilled to bits with it.
http://dashcamtalk.com/g1w/
Whichever one you get, watch out for inferior fakes/clones.
I painted the silver lens-ring and light with matt black paint but the current version is all black anyway.
Here is one of my clips... https://www.youtube.com/watch?v=nnOKQO86KN0
