Old 22nd January 2010, 07:18 PM
Fraz
Guest
Posts: n/a
Default Strange Earth Wire Location - Battery/Aternator/ABS lights -
Hi All, the battery died on my recently aquired 1998 a8 - in the boot have to remove top panel to get to battery and accidently pulled connection from a brown (earth?) wire to the back of the plastic panel.
Charged battery then took for a drive to get a new connector for the above panel. After about 10 mins of stop start driving the 'battery' light on the dash illuminated - i assumed this was warning me of low battery voltage but according to the owners it's alternator warning? Will a low battery throw this warning up or is it likely to be the alernator?
THEN - stop in traffic and the abs warning light would flick on and off everytime i pressed the brake - until it finally stayed on permanently!
Got car back - have reconnected the earth wire and will put on for a decent charge in the morning.
a8 has driven fine until now for past 2 months with no warning lights etc. It has been sat funused for a week hence the flat battery.
So i'm wondering what could be causing ths strange run of bad luck and if there is anything i can do to check what might be causing the problems?
cheers for any help Fraz
Old 22nd January 2010, 08:28 PM
Welcome to the forum, good to have you here.
You can check for a bad earth (symptoms indicate this). Withe the engine running on idle measure voltage across battery terminal + 13.5V or more.
Then on a ramp check from big terminal on alternator to engine +13.5V or more. then check from Alternator terminal to chasis if there is more than .1 V diffeence you have a bad earth on eaither the engine earth cable or chasis earth from battery.
Old 24th January 2010, 02:18 PM
Fraz
Guest
Posts: n/a
thanks for the reply conan - i put the battery on charge again yesterday and it won't hold charge. Had it charging for 8 hrs and dash lights up but wouldn't start up. Left over night and it's flat as a pancake this morning - not even central lokcing will work!
So i need to get a new battery just to see if it will run - is there any special procedure or precaution when fitting a new battery to the 8? Best Regards Antony
Old 24th January 2010, 02:53 PM
No special precautions just attach the + positive first and - negative second.
Old 24th January 2010, 07:47 PM
Fraz
Guest
Posts: n/a
ok thanks again mate - any idea how much a new or reconditioned Alternator wis likely to set me back for a 4.2? Also is the abs light flashing on and off normal when an alternator is on it's way out? Thanks again
Old 24th January 2010, 09:10 PM
Did you fix that wire that you'd pulled on the battery? Just wondering if that may be causing some funny gremlins.
Old 25th January 2010, 08:46 AM
Fraz
Guest
Posts: n/a
hi yes replaced the small earth wire but haven't got the car running since. So i've got a new battery - when i fit it and try to run the car is it going to knacker my new battery if the alternator is duff?
