As some of you may or may not be aware Ross Tech dont always share every snippet of info in VCDS lbl files.
The reasons are plenty, from protecting us from killing the car or ourselves to not having time to do it, whatever the reason I always want more. ![]() So having stumbled across info thats both safe to use (with common sense) and useful I thought I would modify the VCDS lbl file for the Level control. The file I have attached is for D3 Air suspension controller and has been tested to work as intended. Simply download the file, and paste it into your C:\Ross-Tech\VCDS\Labels\User folder then unzip it. Then the next time you use VCDS when you select control module 34 VCDS will use the file from your user folder. The modified file allows you to Login and Bleed / Charge suspension components. Its not something you will need everyday but should you need it, it will save you faffing around no end. To use the features select module 34 in vcds, then security access, when you hover the mouse you will see extra info regarding bleeding with the login code, enter it, then click do it. then click on basic settings, once in you will see a drop down box with the various options. They are self explanatory, one notable exception is the Accumulator charge, it occurred to me that is a good way test the air compressor as it only charges the accumulator and nothing else. Max pressure of the system is 16 bar, I stopped mine at 15.5 bar as thats more then enough and shows the compressor is healthy. When you click on the On/Off/Next button to activate a command it will time out after a short period, thats normal and if you want to charge or vent some more just click it again. ![]()
Del ![]() |
Great info Del - thank you and added to sticky for this section
Del that is Highly Valuable info there "Thank you Sir
![]() Off to test this Right now |
Delboy - do you know if this will work for other Audi wagons ? or if its a8/s8 specific ?
Wifes got a Q7 and suspension seems too harsh... was hoping could adjust using this hack any ideas?
Phantom Schwarz D3 2006 3.0 TDi remapped Valcona Black Leather, Bose, 19" BBS, VCDS Lowered, Xenons, Bluetooth and still lots to do... Blue 2007 Audi Q7 3.0 TDi S-line Heated Seats, Leather/Alcantera, Auto Boot, Sat Nav (NOT WORKING !), Bluetooth, 20" alloys. |
It is only for diagnostic and servicing purposes as its temporary and not permanent. An example would be if you were changing a strut unit you would bleed down the appropriate axle to de-pressurise the strut prior to removal, then once the new one was fitted you can charge that axle to perform leak test and to preload the shock prior to bearing weight once off the ramp or jack.
Del ![]() |
just figured that out
changed the filename to match the part number on the Q7... was able to do the checks but realised they reset after a restart. so this brings me back to my issue - i have a Q7 which was riding nice up until the compressor was replaced. it now rides very hard with almost no give, even in comfort mode. Any suggestions as to what/where i can look for an answer ? many thanks Bal.
If you change the modes from lift to dynamic is the ride height changing , if it been lifted on a ramp without being in jacking mode could it of gone in to a limp mode so the active side as stopped working , need vcds really to check codes and see if any basic settings need re initialising
ride height is changing with the different modes
i've re-calibrated the suspension with the real figures to get it to stock - no difference in harshness. There are no fault codes in VCDS for air suspension the compressor was changed recently and its since that change that we felt the difference. Before that dynamic was fairly tight and comfort was... comfortable. now harsh in comfort and brutal in dynamic. what would constitute a reset ? Do you know if there are any values/measurement blocks i could be looking at to find fault ?
Phantom Schwarz D3 2006 3.0 TDi remapped Valcona Black Leather, Bose, 19" BBS, VCDS Lowered, Xenons, Bluetooth and still lots to do... Blue 2007 Audi Q7 3.0 TDi S-line Heated Seats, Leather/Alcantera, Auto Boot, Sat Nav (NOT WORKING !), Bluetooth, 20" alloys. Last edited by BADES; 14th November 2015 at 09:13 AM. |
Does the Q7 have the same style of adaptive shocks as the A8?
There are sequential test that can be ran against 34 level control, cycle through them an somewhere there will be tests that feed current to the shocks, minimal current is hard and maximum current is soft. Only other thing I can think of with out digging deeper into checking wiring and coil values on the shocks would be fuses. On the A8 there is more then one fuse that feeds the level control and it would be worth studying current flow diagrams and figuring out if its the same and checking them.
Del ![]() |
Thanks for the ideas - i will check out the fuses etc.
![]() as an update - the suspension is a little softer since running the tests as per the original post !!! I cannot explain it. as i said before, i de-pressurised the front and back suspension to 'try' to soften it up and hoped it would remember the settings... not sure why its worked, but its going the right way. If i get time, i will try to investigate more... for the meantime - Thanks Del. ![]()
