Old 2nd July 2019, 11:19 AM
onetwentie onetwentie is offline
Default D3 Front bumper mountings/bolt
Hi All
So in the process of removing the alternator from my 2007 D3 and need to remove one of the front bumper (driver side front wheel arch) mountings, which is attached to the front wing with a 15mm nut. One of the 3 bolts then goes through this and is secured with a 10mm nut.
The problem is, the nut mounting I mentioned won't come off, so I'm likely going to need to shear it off and replace it.
I would be grateful if someone could point me in the direction of an exploded diagram so I can start to source a spare?
thanks all in advance.
Current: 2007 Audi A8 3.0 TDI SE Quattro -
