Old 13th May 2014, 07:47 PM
Default Umbrella Holder Retrofit
Hi folks here is a quick how to on fitting the brolly holder to the toolbox in the boot.
So you will need
3 x Screws (N 91090701)
1 x Umbrella holder (4E0860264) list price is 14.68 inc vat
The unit is fitted by cutting the toolbox like in the following pictures and then drilling three holes for the screws to hold the part on.
In order to find where the holes need to be cut I put tape on the cover so I could mark where to drill one the big hole has been cut.
Start by cutting a small hole in the middle with a stanley knife approximately where the protruding part sits, once you have a hole big enough for you finger to get in you will feel a recess that the grip will sit into, continue trimming the hole out till you are at the edges of the recess and then you can place the grip in the hole and centre it.
Then trace round the grip with a pen so you have an outline, you can then transfer the measurements for the mounting holes or carefully peel of the masking tape and poke through the tape into the holes as i did then stick back onto the box for drilling of holes.
Once your holes are drilled, just have to refit and stand back and admire your handy work.
ID:	8065   Click image for larger version
ID:	8066   Click image for larger version
ID:	8067   Click image for larger version
ID:	8068   Click image for larger version
ID:	8069   Click image for larger version
Old 13th May 2014, 08:31 PM
Somerandomguy's Avatar
Nice, i think I'll add that to my list of upgrades too
Old 13th May 2014, 08:58 PM
Any reason why you couldn't fit that to a D2?
Obviously, not in the exact same place as there's a warning triangle there, but above the inside handle looks OK.
Old 13th May 2014, 09:07 PM
My very thought....... and up here you ALWAYS need an umbrella to hand!
Old 13th May 2014, 09:40 PM
yes I do remember a certain wedding David!!
But guess its ok if you happen to be a Laird, you have minions to appear with umbrellas when required!!
Old 13th May 2014, 09:50 PM
What does the inside of the d2 toolkit look like?
Old 14th May 2014, 06:22 AM
Well done Del, good job
Old 14th May 2014, 06:38 AM
It sits in the spare wheel well, the big empty space houses the removable towbar if you have one fitted.
Old 14th May 2014, 08:32 AM
Conquistador's Avatar
Nice guide, thanks.
At the moment I've got an umbrella shoved through the two fabric loops that are attached to the two big plastic hooks that spring down from the top of the boot.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 14th May 2014, 09:18 AM
If anyone wants a 'tastefully' branded one, there are Audi umbrellas on aliexpress, it is an auto brolly in charcoal and has grey reflective Audi symbols (that's why they appear white in some photos due to flash). I bought a couple and put one in each rear door pocket.
http://www.aliexpress.com/item/Audi-...762280297.html
