I'm working on the theory that the shocks will likely benefit from a change soon, and if I'm doing that may as well do the springs
the first choice in my head is Bilsteins. So I've been doing some digging and thought I'd share Mines a 2002 S8 so if I understand correctly; S8 is 25mm lower than corresponding A8? Eibach lowering springs are circa 25mm lowering on an A8 so can be interchanged with the S8 on standard Sachs shocks or replacement Billies? Part number is E1533-140 https://www.eibachshop.co.uk/eibach-..._p31223052.htm Bilstein do a B12 kit for the D2, which according to their website is a package deal of the Eibach springs and B8 dampers. B8 being B6 spec but shorter to allow for the drop. That said I can find B6 shocks listed but not B8, so I wonder what's in the kit? FRONT BILSTEIN B6 - SPORT SHOCK ABSORBER - 24-066785 (Facelift) https://www.bilstein-shocks.co.uk/se...ct&q=24-066785 CAR FITMENT: A8 (4D2, 4D8) 2.5 TDI 2.5 TDI quattro 2.8, 2.8 quattro 3.3 TDI quattro 3.7 quattro 4.2 quattro 6.0 W12 quattro, S8 quattro (06/99-09/02) CH.Nr.: 4D-1-000 001 Listed as compatible with OEM S8 Audi 4D0 413 031 CD FRONT BILSTEIN B6 - SPORT SHOCK ABSORBER - 24-026093 (Pre Facelift and Facelift) https://www.bilstein-shocks.co.uk/pr...5ed20c02&_ss=r CAR FITMENT: A8 (4D2, 4D8) 2.5 TDI, 2.5 TDI quattro, 2.8, 2.8 quattro, 3.7 quattro, 4.2 quattro, S 8 quattro (07/96-09/02) CH.Nr.: 4D-Y-020000 Listed as compatible with OEM S8 Audi 4D0 413 031 CD REAR BILSTEIN B6 - SPORT SHOCK ABSORBER - 24-026161 (Facelift and Pre Facelift) https://www.bilstein-shocks.co.uk/pr...755cb1fc&_ss=r CAR FITMENT: A8 (4D2, 4D8) 2.5 TDI 2.5 TDI quattro 2.8, 2.8 quattro, 3.3 TDI quattro 3.7 quattro, 4.2 quattro 6.0 W12 quattro S8 quattro (06/99-09/02) CH.Nr.: 4D-1-000 001 ------------------------------------------------- B8 Shortened performance Damper (use for A8 with lowering springs or S8 with standard springs) B8 not listed for D2 A8 Bilstein B12 Sportline kit contains B8 Dampers Eibach Sportline Springs B12 Sportline not listed for D2 A8 Bilstein B12 Pro Kit contains B8 Dampers Eibach pro Kit Springs BILSTEIN B12 PRO KIT - 46-193810 https://www.bilstein-shocks.co.uk/pr...a3c8e4a7&_ss=r CAR FITMENT: A8 (4D2, 4D8) 3.7 quattro 4.2 quattro (03/94-09/02) CH.Nr.: 4D-Y-020000 VA: lowering (expertise): 25 mm; axle load to: 1254 kg HA: lowering (expertise): 25 mm; axle load to: 1230 kg BILSTEIN B12 PRO KIT - 46-193834 https://www.bilstein-shocks.co.uk/pr...a3c8e4a7&_ss=r CAR FITMENT: A8 (4D2, 4D8) 3.7 quattro 4.2 quattro (11/98-09/02) CH.Nr.: 4D-1-000 001 VA: lowering (expertise): 25 mm; axle load to: 1254 kg HA: lowering (expertise): 25 mm; axle load to: 1230 kg BILSTEIN B12 PRO KIT - 46-193841 https://www.bilstein-shocks.co.uk/pr...a3c8e4a7&_ss=r CAR FITMENT: A8 (4D2, 4D8) 2.5 TDI 2.5 TDI quattro 2.8, 2.8 quattro (04/96-09/02) CH.Nr.: 4D-1-000 001 VA: lowering (expertise): 25 mm; axle load to: 1255 kg HA: lowering (expertise): 25 mm; axle load to: 1230 kg BILSTEIN B12 PRO KIT - 46-193827 https://www.bilstein-shocks.co.uk/pr...a3c8e4a7&_ss=r CAR FITMENT: A8 (4D2, 4D8) 2.5 TDI 2.5 TDI quattro 2.8 quattro (04/96-09/02) VA: lowering (expertise): 25 mm; axle load to: 1255 kg HA: lowering (expertise): 25 mm; axle load to: 1230 kg I've emailed Bilstein to try and find out what's in the B12 kit exactly. In the mean time any thoughts on the above appreciated. |
Why not buy the OEMs again? They are on tradition and eBay too
interesting I thought the s8 red sachs were NLA?
4D0413031CD isn't listed on Tradition or ebay.
The B12 kit does sit the S8 at about stock ride height. Its made with B6 dampers rather than the B8s as far as I can tell - they certainly aren't any shorter than the stock Sachs units. |
I am in the process of rebuilding my suspension with Bilstein B6 dampers. I am using the old springs, but have had them re-painted.
I used parts numbers 24-066785 & 24-026161 and got one pair from Autodoc and one pair from www.bilsteinsuspensionstore.co.uk (as that was the cheapest way). Cost just under £500 for all four. Nowhere near to the point of driving the car though, so cannot tell you how they feel unfortunately!
Audi S8 D2 2002 |
anyone know if the top mounts are available? suspect the may also be past their best
thanks MJ are they the same front and rear?
Those are fronts. Rears are not available, but luckily don't tend to wear out.
4D0512169D if you want to try and find some - I've previously drawn a blank but its always worth poking around just in case ![]() Last edited by MikkiJayne; 22nd June 2022 at 09:28 AM. |
thanks
yeah I'm not seeing anything listed for those anywhere |
