Solution: Hit with your biggest hammer until you feel better and return to MOT station. Initial reading 179 O/S, 11 N/S
![]() Put the new caliper on yesterday and now I only have 2 clicks to engage the handbrake compared to the full extension I was using so the lesson for the day is if your handbrake comes up more than two or three clicks then something is broken somewhere.... Bill
"Man Math" - The means by which a caring husband convinces his wife that a 4.2 A8 is in fact cheaper to run than a tiny Auto crap box "Being in touch with your feminine side" - The ability to, in the 30 seconds following a major accident, obtain your wifes approval for replacing your big german car with another "because otherwise we'd be dead". See also sulking for two years until she finally allows you to get another purely on the basis of your current one being the wrong colour. |
I had the same problem with the S2, in fact both rear calipers were not returning to their stops - solution : 2 new rear calipers, no hammers were used and no calipers were harmed in the process...
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten ![]() |
Must be an Audi design problem. My 90Quattro suffered from seizing handbrake quadrants - usually noticed at MOT time! As I had the car for *many* years I started to replace them proactively whilst being serviced etc. Result no further problems. In the interim, every time you can get underneath the car, give them both a spray with WD40 or similar.
Chris
D2 FL Q 2.8 V6 2002 Taxi(?) spec - no heated seats headlight washers etc. D2 PF Q 2.5 tdi LHD rear blinds and heated rear seats, Bose, 5 speed Tip, Servotronic, Pioneer AVIC 333,333 km Murdered on a P&O ferry 2012. Cat3 write off |
Strangely when I came to do my brakes last year the rear calipers had already been replaced but they had left old discs in which were a fraction of the cost - seemed like false economy to me for the sake of about 50 quid to do both sides
My rear brakes work properly but If I use the handbrake then the n/s sticks on.
I put took the wheel off and spent a while applying the handbrake and then using a hammer to release it as the return spring could not release the h/b. Even though I splashed a load of WD-40 on it as I worked, it still sticks if applied. Is there more I could do apart from replace the caliper? It's an early FL so it's got the pukka Brembo brakes...not in stock at A8 parts. |
Simon,
All rear brakes are Girling. It is more than likely to be corrosion of the piston which means it wont sink back into the caliper. Stop hitting it with the hammer, disasemble from the carrier and remove the dust seal. If the dust seal has failed Moisture will have got in. The temp repair procedure is here.
I think you have two options..
1 - As Mike says above.. or 2 - You need a bigger hammer ![]()
Conan.
By George, I think you've got it! Your explanation makes perfect sense as plainly what I was doing with the hammer (hitting it), would not affect the way that the piston travels. I'm just surprised at Audi. I'd expected these pistons made out of Stainless. ![]() On second thoughts, how come the 'pedal' brake don't stick on then? Is the handbrake not the same piston? Last edited by Simon Wallwork; 27th October 2010 at 06:04 PM. |
It is and you can test it by driving for a mile or two and feeling the disks 'carefully' with a wet finger, It will hiss on a stuck calliper and warm gently on a properly working one.
Conan
The brakes only get hot if I've used the handbrake. They don't bind at all otherwise, so it's a problem with the h/b mechanism. But how to fix it??? ![]() |
