VCDS (aka Vagcom) For all your electronic debug / diag advice queries and mods. |
Rather than post this giant data dump within the many threads it's going to precipitate, I decided to stick it here in its entirety and only put the related excerpts in those threads. good idea, huh?
And its 2x too long per the forum's software! I'll delete some unnecessary stuff (dashes and spaces) and split it in two. Thursday,08,March,2012,13:54:13:64698 VCDS Version: Release 11.11.2 Data version: 20120126 -- Chassis Type: 4E0 VIN: WAUML44EX4N001183 Mileage: 236030km/146662miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 75-Telematics -- Status: Malfunction 0010 76-Park Assist -- Status: Malfunction 0010 - Address 01: Engine Labels: 077-910-560-BFM.lbl Part No SW: 4E0 910 560 A HW: 4E0 907 560 Component: 4.2L V8/5V G 0050 Revision: 00000000 Serial number: AUX3Z0C2512094 Coding: 0007773 Shop #: WSC 98765 666 30770 VCID: 1F4D5514CEA6FDB No fault code found. Readiness: 0000 0000 - Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 E HW: 09E 927 156 A Component: AG6 09E 4,2L5V USA 0060 Coding: 0000002 Shop #: WSC 02353 785 00200 VCID: 24475AF8E7C0DE3 1 Fault Found: 17087 - Brake Switch (F) P0703 - 000 - Electrical Malfunction - Intermittent Freeze Frame: RPM: 640 /min RPM: 192 /min RPM: 32 /min (no units): 7.0 (no units): 34.0 Temperature: 70.0°C T.B. Angle: 0.0° Voltage: 13.92 V - Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 A HW: 4E0 614 517 E Component: ESP 5.7 allrad H29 0420 Coding: 0007597 Shop #: WSC 03419 000 00000 VCID: 214953ECF8D2CBB 2 Faults Found: 00526 - Brake Light Switch-F 011 - Open Circuit - Intermittent 00526 - Brake Light Switch-F 008 - Implausible Signal - Intermittent -- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 A Component: FBS AUDID3 H02 0110 Revision: 01103502 Serial number: AUX3Z0C2512094 Coding: 0263168 Shop #: WSC 02313 785 00200 VCID: D8BFBE086B08CA3 Part No: XXXXXXXXXXX Component: ELV XXXX 1 Fault Found: 00172 - Key 2 not learned 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 5 Fault Frequency: 0 Reset counter: 245 Mileage: 234864 km Time Indication: 0 Date: 2012.02.26 Time: 17:04:28 -- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H06 0050 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3940576 Shop #: WSC 02313 785 00200 VCID: 234559E4E2CED9B No fault code found. -- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 729 B HW: 4E0 035 729 Component: Interfacebox H43 0150 Revision: 00000000 Serial number: 346D8037502020 Coding: 0000103 Shop #: WSC 02353 785 00200 VCID: 275D4DF496F635B Part No: 4E0 910 611 Component: E0380 BedienteilH01 0050 No fault code found. - Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 B Component: KLIMAAUTOMAT 015 0240 Revision: 065A0000 Serial number: 898053000 Coding: 0037185 Shop #: WSC 02313 785 00200 VCID: DABBA4001504D83 Part No: 4E0 910 772 Component: Sitzluefter FS H05 010 Part No: 4E0 910 772 Component: Sitzluefter BFS H05 010 2 Faults Found: 00728 - Potentiometer in Positioning Motor for Left-Hand Central Vent (G136) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 238 Mileage: 234568 km Time Indication: 0 Date: 2012.02.23 Time: 07:25:16 Freeze Frame: Voltage: 13.40 V (no units): 0.0 (no units): 0.0 00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 242 Mileage: 234592 km Time Indication: 0 Date: 2012.02.23 Time: 08:15:28 Freeze Frame: Voltage: 13.70 V (no units): 207.0 (no units): 255.0 -- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 E HW: 4E0 907 279 E Component: ILM Fahrer H11 0100 Coding: 0111003 Shop #: WSC 24103 444 84355 VCID: 2A5BB4C085E4083 Subsystem 1 - Part No: 4E1 910 113 Component: Wischer WWS D3 H30 0320 Coding: 00000030 Shop #: WSC 24103 No fault code found. - Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 HW: 4E0 035 111 Component: CD-Changer H43 0220 Serial number: AUZ5ZBC1012376 Shop #: WSC 00000 000 00000 VCID: D6A3B030611CFC3 1 Fault Found: 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 6 Reset counter: 7 Mileage: 233449 km Time Indication: 0 Date: 2012.02.16 Time: 17:37:50 Freeze Frame: Bin. Bits: 10 -- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 A HW: 4E0 959 655 A Component: Airbag 8.4E+ H08 0820 Coding: 0530707 Shop #: WSC 02353 785 00200 VCID: 24475AF8E7C0DE3 No fault code found. --- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 A Component: Lenksäulenmodul H09 0030 Coding: 0012241 Shop #: WSC 02313 785 00200 VCID: E5C187FC2C7A67B Part No: XXXXXXXXXXX Component: Lenkradmodul H02 0050 No fault code found. -- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 950 B Component: KOMBIINSTR. VDO H42 0060 Revision: D07 Serial number: AUDID3C2000250 Coding: 0000223 Shop #: WSC 03213 444 04780 VCID: DCB7A2181F30263 No fault code found. -- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 A HW: 4E0 907 468 C Component: Gateway H06 0020 Revision: 06 Serial number: 50003222012801 Coding: FCFE7BDD1B2304 Shop #: WSC 98765 666 30770 VCID: 264340F091FC2C3 No fault code found. -- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 A Component: FBS AUDID3 H02 0110 Revision: 01103502 Serial number: AUX3Z0C2512094 Coding: 0263168 Shop #: WSC 02313 785 00200 VCID: D8BFBE086B08CA3 Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 1 Fault Found: 00172 - Key 2 not learned 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 5 Fault Frequency: 0 Reset counter: 245 Mileage: 234864 km Time Indication: 0 Date: 2012.02.26 Time: 17:04:28 TO BE CONTINUED... - |
