Old 30th July 2011, 04:44 PM
gninnam gninnam is offline
Default New disks and pads
Brake pad warning light came on a week ago so decided to change the pads.
Got them this morning from GSF and then set about changing them.
Decided that the discs have seen better days so bought a set of these.
OK - read all the previous posts about the bolts holding the calipers on and being a bitch to get off, but noticed that the caliper on the outside is held in with a couple of nuts - could I just undo these (they are like larger allen key style nuts - about 12 MM across I think).
If I could get this off, then the outside pads will just fall out and I'm sure the brake disk will also come off.
Should I do this??
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 31st July 2011, 10:10 PM
motn motn is offline
The disc won't come off with the carrier still surrounding it - you will have to tackle the very difficult carrier bolts!
I quickly realised human strength wouldn't get mine off, so I ended up using a breaker bar with the end touching the ground, then lowered the car so that the car's weight would undo the bolt.
Old 1st August 2011, 09:19 AM
Big spanner... Big Hammer on the bolts at the back
I assume the D2's similar, but the D3 caliper bolts go on at 190Nm (or big belt with a hammer).
Interestingly, the D3 rear disc will come off with the caliper mount still on.
Old 1st August 2011, 09:58 AM
Cheers guys.
Seeming that the pads have plenty of live left in them, I think I will avail myself of my friends garage when he comes back off his hols and use his more manly tools (if you know what I mean).
Andy.
Current cars:
BMW i4 M-Sport
Old 15th March 2012, 08:46 AM
graynada graynada is offline
Can anyone confirm that the carrier bolts are 18mm? Just it's a non standard size and I don't want to tackle it with the wrong socket
Old 15th March 2012, 08:49 AM
I think they are from memory, though maybe 19s. And they usually need a good smack to get them off...
I usually do the bottom one first as it's easy to get to, then knock the caliper carrier a bit to loosen the top one off.
Old 15th March 2012, 09:36 AM
They are definatly 18mm. I use a old ratchet and take a hammer to it. Just make sure you do them up tight enough
Old 15th March 2012, 09:46 AM
47p2's Avatar
47p2 47p2 is offline
A six sided socket is the best for this as it is less likely to slip and damage the head of the bolt.
Nite Blue 3.0L SE Quattro
Old 15th March 2012, 10:27 AM
Thanks guys and I was thinking six sided socket might be best.
Old 15th March 2012, 10:31 AM
Or one of the big spanners from Halfords (not the staff!) to save your ratchet.
