Old 19th May 2012, 10:49 PM
Default Screenwash level fault
Annoyingly, when the screenwash runs low, the DIS has a lovely, if somewhat overanimated graphic that sits on the top line telling you to fill up.
The problem occurs when you already filled up, and the dam thing keeps going.
The screenwash bottle sits underneather the drivers side wing, and has two pumps in it. The one lowest down feeds the windscreen jets, and incorporates a level sensor. The 2nd one is higher up, and feeds the headlampwash, which was standard facelift, and optional preface.
So, I needed to change over the bottom-most pump which was ok, as I have a donor car. The easiest way to access them is to remove the drivers side headlight:
Once removed, you can see the pumps, and work them out with a bit of jiggling.
The bottom one is circled in green, the top one in red.
Getting them out was ok, but when I put the pump back in, it pushed the rubber sealing grommet through into the tank. This meant I had to remove the whole tank to get it back again.... Aarrgh. !!
So, airbox out, wheel arch liner out, a bit more wiggling and out it came. I retreived my grommet, put the pump back in *carefully*, reassmebled the whole lot and hey presto, warning light gone..
ID:	3494   Click image for larger version
ID:	3495   Click image for larger version
Old 20th May 2012, 06:44 AM
Mine had the same fault after I got it, on a pump that was less than a year old! Thankfully sorted by the garage that fitted it foc!
