Its not uncommon for the RNS-C navigation units to develop a fault where the screen flickers. Moving the screen around a bit sometimes gives some breif relief but its annoying and persistent. I've only seen it on RNS-C - RNS-D doesnt seem to suffer the same problem.
The problem is a ribbon cable that becomes unseated, and fortunately, its a simple fix, no more than 30 mins. Firstly, you will need removal keys to remove the Sat Nav unit, and you will need the code as disconnecting the power will leave it in safe mode. You will also need a small philips screwdriver a Torx T8 and a Torx T9. A small flat blade will prove invaluable too. So, once you get it out and on the bench, start by removing the 4 T8 screws from each side highlighted: Lift the front down very gently. There isnt a great deal of play in the cables: Disconnect each of the 4 cables. They will pull out with a gentle tug. Then you need to remove the 2 x T9 bolts that holds the screen in: And it all lifts out as so - Then undo the 4 small crosshead screws. You can then prize the plastic frame away from the screen: Once seperated, use the small flatblade to push out the clasp that holds the ribbon cable into the screen: And pull the cable out completely: Then - Refit the ribbon cable. Push it in nice and tight. Then push the retaining clip back in place. Refit the screen into the front housing: Next, pull out the clasp on the connector at the other end of the ribbon cable on the main unit: Now - Offer the front back up to the main unit. Connect the power and 2 control cables first - This stabilises the whole thing and makes it much easier to cope with the ribbon cable. Again, push this in firmly, nice and square, and push the clip in to secure it. Also, make sure the control cables tuck away nicely into the recesses as they tend to stray like this one: Final check, make sure all cables and home and not snagged. Press the front on - Do up the 8 retaining screws and test - The screen should now work well, without any distortion ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
