D2 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
My fronts are about 45-50% more worn than my rears, I read somewhere it is recommended to swap them around to get the best life out of them? Is this true? If so, will swap them around when I paint my calipers!
2009 Audi RS 6 Saloon V10 - 420mm Ceramics, Keyless, Soft Close, Adaptive Cruise, Glass Sunroof, Blinds, Twin Pane & UV, Freeview & DAB, High Beam Assist, MTM bits, Audi Exclusive Bits, MRC, Milltek, GYEF1 ASY2's, Bluetooth streaming music to AMI mod - 753 PS/1021 NM 2016 Audi S3 Saloon, Sepang, S-Tronic - B&O, Tech Pack etc... Company Car 1995 Audi A8 4.2 V8 quattro Sport - Bose, Solar, Blinds |
On my cars i usually swapped then at ~ 15K miles although up to now I've never had 4WD so not sure if I should do it 2 or 3 times instead of the once.
On mine currently teh fronts at ~ 75% worn, the backs about 50 so when I get to washing it next week I might swap them |
I just swapped mine round on the S4.
I keep an eye on mine and as soon as I spot more wear on the fronts than the rears, I swap them around. Well worthwhile IMHO - the fronts naturally wear more than the rears, so you're simply getting maximum use from the tyres.
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten ![]() |
