Old 16th September 2012, 02:32 PM
m3csl m3csl is offline
Default Timing belt or chain
Hi All
When I bought my 1998 D2 4.2 S8 it had no history,so can someone tell me if the S8 has a belt or chain and at what mileage should they be checked or changed.
Many thanks
Old 16th September 2012, 02:37 PM
Nollywood's Avatar
All petrol-engined D2's, from the 2,8 V6 - 4,2 V8 are belt-driven. There is a chain linking both inlet and exhaust cams though, but the main drive from crank to cams is via belt.
Old 16th September 2012, 02:42 PM
Hi Thanks for quick reply,at what mileage should the timing belt be replaced.
Old 16th September 2012, 04:36 PM
IIRC it's around 100,000 miles. For some strange reason 105,000 sticks in my mind.
sporran sporran is offline
Audi reckon they should be changed every 74,000
Stevie
Old 16th September 2012, 04:58 PM
I'd go with 5-6 years or 70k miles.
Old 16th September 2012, 07:43 PM
It's 120k km which works out around 75k miles. On some models it also says 120k km or 5 years whichever comes first, on others just 120k km without time period.
Old 16th September 2012, 08:53 PM
mannyo mannyo is offline
Mine had its second replacement at a long overdue 174K miles and 10.5 years old back in January, its first change by the previous owner was also slightly overdue. Mine is now well on the way to 181K miles, and it seems to be fine on the belt front despite 2 late changes.
Manny
Past
Old 28th October 2012, 07:19 AM
Richierich37 Richierich37 is offline
My 02 A8 had a belt change at 61k miles, its now sitting at 129k! Would it be a wise move to get this and the water pump done? Parts alone are around £385, so its not going to be a cheap job inc. labour!
Old 28th October 2012, 07:35 AM
Yes I would definitely get it done now Rich, its normally 75k miles or 5 years whichever comes first so you are close on mileage and not sure on time?
its definitely worth getting the water pump and tensioners / rollers done at the same time - I had the serpentine belt done also. most of the V8s also need the thermostat changing at the same time as for the low cost its a no brainer as its hard to get to normally. not sure on that on the V6 though so check it out first. You are on the nail with parts costs at around £400 and quotes i originally had for my V8 recently were £640 from an indie and £880 from Audi but they did mine for a £100 inc vat in the end at Audi (subsidised by head office due to "issues" on another car) so I wasn't complaining!! The car is looking excellent by the way
