Old 30th December 2012, 08:56 PM
Mutley Mutley is offline
Default Rear brake disks and pads replacement
Looking at them I think they need replacing plus I got a vibration that started when I braked from 80-90 (sorry I meant 70), which has ome down now to around 30 so convinced ones warped (left rear)
Where do you get yours fom and which ones, in searching I'm finding 2 listed for a D3 4.2, the 280mm and 300mm.
2003 Audi A8 D3 4E, 102K Miles, 20" Alloys, 4.2 Quattro
Fixes i've resolved myself and with the help of the forum and Vagcom
  • Update MMI to 5570
    Hidden Menu
    Brake Switch Repair and ESP Light
    Reset Parking Brake Calibration
    Removed Speed Limiter
    TV In Motion
    Reset and resolved issue with Cruise Control
    Coming Home Lights
    Lowered 10mm
    MMI Replacement brass gear for silky smooth action
Old 31st December 2012, 11:26 AM
I got mine from eurocarparts.. They usually have the 3 letter build code in their description so you can pick the right size, then decide whether to buy from them or elsewhere.
Last edited by PsYcHe; 31st December 2012 at 02:45 PM. Reason: *ahem..3 letter build code
Old 31st December 2012, 01:55 PM
I second http://www.eurocarparts.com/
The sale ends tonight I think. EDIT***Jan 1st midnight ****
Take a photo of the sticker in your wheel well for the codes.
These should match the codes on ECP website to make sure you get the right parts, e.g. 1LL, 1LJ, 1LM etc..
I would also then check ebay for price comparison.
Old 31st December 2012, 04:35 PM
sarg sarg is offline
you might want to check suspension components for worn bushes too
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 1st January 2013, 09:07 PM
green A8 green A8 is offline
I agree with the above, had exactly the same problem with a company D3 A8 I told Audi I was 100% certain that the rear discs were warped, so they replaced them along with the pads. I had the car back less than half an hour, had to perform a bit of sharpish braking (idiot undertaking on the hard shoulder to 'dive' off the Mway) same problem all over again. I returned the car to Audi rather sheepishly they investigated and replaced a rear suspension arm or bush. Problem sorted. Hope this helps.
Paul
