Hello,
have D3 2006 3 L. TDI and have really loud sort of engine rattle, i know most of us going to say chain, but was listening very carefully and its coming at the bottom of the engine, sort of where engine joins with torque converter, changed that common problem cam tensioner on right hand bank, but just after that went to look where is the noise coming from. My opinion 3 possible things, either main chain, oil pump or torque converter, then you listening for noise from bonnet open end its sound rattly, but when its on the ramp and try to listen from underneath its very noisy. In the morning or when engine off for good few hours no noise for about max 5 min and then its starts to rattle. Any opinions lads? |
Hey dude iv got a similar problem, but mine only rattles for the first 5 seconds on a cold startup. Or if a hot engine has been left off for a while.
Iv posted a thread so ill let you know how i get on, Did you manage to get yours sorted. |
There is a TSB about the injectors causing this type of rattle on startup when they dribble diesel while the engine is off for some hours.
Does tsb stand for technical servce bulletin, if so where can i find out about this,
Thanks |
