Old 23rd May 2013, 09:05 PM
OwwDee OwwDee is offline
Default Wheel Bearing
I have a rumbling noise coming from the Left side which seems to alter with road speed. I suspect a wheel bearing, although I am unsure whether it is the front or the rear. I am thinking of doing both, maybe even all four. Has anyone done a wheel bearing change and what are the pitfalls?
My car is a 2004 4.0TDI Quattro with 190,000 miles.
Old 24th May 2013, 07:21 AM
Dave McB Dave McB is offline
i need a wheel bearing done on my D2.
The bearing is not the issue, its a press fit.
Unfortunately, the whole hub will need to come off to press out the old bearing & in the new one.
Other than that, no major issue.
I would suggest you get someone to check all wheels & only do the one that needs done, otherwise youre in for a hell of a job
