Old 2nd July 2013, 09:54 PM
Davie b Davie b is offline
Default Initial vcds issues
Hi guys ,
I've had a go with my new genuine VCDS tonight ,
On selecting auto scan and after selecting for the D2 it comes up with modules to scan
Scan 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77 02
Then it cycles through to 56 and throws up a fault code
56 radio
1 fault found
01044 control module incorrectly coded 35-00- -
Any ideas what that is or how to fix it ???
Then after that it goes to module 57 and then stops and I get an error saying
Interface status = 0
Interface not ready
Possible reasons
Incorrect com port selected
Interface not plugged in
Ignition not turned on
K-line stuck
Firmware update needed
For more details use test on options screen
Any ideas why , module 57 is for the TV and my car doesn't have one , is this the reason why it's not continuing or is there a problem elsewhere
Dave
Old 3rd July 2013, 01:23 PM
sounds like the CAN module is coded for TV. check the coding on module 07
Old 3rd July 2013, 01:27 PM
Cheers mate ,
How do I know if it is or not , I didn't think mine supported CAN , or am I getting confused here with something else mine is a PF 1998 S8
Old 3rd July 2013, 04:02 PM
PF, so no CAN .. Could be that the radio has the coding in it for TV.
Go into coding in VCDS and it should have helper hints for it.
Old 3rd July 2013, 04:33 PM
Thanks mate ,
I'll have a butchers when's get home tonight
