Typical....sales through its MOT and then 3 days later...keyless entry and the lock buttons on doors spop working intermittently!
![]() Could it be the heat??? only say this as after washing the car it worked, but then failed again after parking up and going back to it. Keyless start is fine but I changed the keyfob battery's just to be sure and its the same!! The boot open is the one I miss the most...still works fine if I just use the key fob... As I'm good with a soldering Iron I'm hoping its just a dry joint on a circuit...but would need to know where the modules are...aerials and control etc... All help appreciated as usual!!! I think its heard me talking about getting an RS6/S6 next.... ![]()
Rossy ![]() ![]() Digital Remap Twin Cone Filters Upgraded 19" Rims Back Box deletes with SS quad exits |
The first thing I would do is to change the battery in the remote. I have had this occur when the battery is getting low but is still ok to plip.
Beyond that if it is happening everywhere, you may be into a control unit, but try the battery first as mine was temperamental on low battery.
Deep Green 2006 '56' A8 4.2 SE, B&O & Exclusive Interior Extended Aluminium, Oak Sepia Wooden Trim, Extended Leather Green Exclusive Dual Colour, Heated Comfort Leather Interior Green Alcantara Headlining, Pillars, Rear Shelf, Door Inserts Green Trimmed Mats, Seatbelts, Steering Wheel, Centre Armrests DAB, Freeview, ACC, 4-Zone Climate, Soft Close, Electric Blinds |
You need to pull codes from keyless entry module.
As I already said, changed the Battery's in the Fobs already...its intermittent...
Still using the button start, so once in the car it knows I have a key. Just want to know where the modules are... I think I found out there are two aerials in the rear bumper for example! It either damp a loose connections or a dry joint as it can work perfect then not at all....just need to know where to look???? Thanks
Gone altogether...
![]() ![]() ![]() ![]() I actually have to put my key in the dash to start it!!!!! Sacrilege! Booked in at the Stealers for 815am.... A5 Technic or A6 S-Line on offer as loaner... ![]() Will be looking at any S6's while I'm there and get a Part Ex price of them... ![]()
Sounds like the remote unit has probably failed.
You may be getting water in there too, happened to my PF D3.
