Old 10th May 2012, 09:01 PM
Somerandomguy's Avatar
Default Retrofit Ski hatch?
Has anyone retorfitted a Ski Hatch? I miss the ability to carry the odd length of timber/copper, so was wondering if anyone had done this and if there are any gotchas?
cheers
Old 10th May 2012, 09:16 PM
Can be done, but it needs the hole cut in the panel behind the seats.
Old 11th May 2012, 05:11 AM
The hole is already in the panel behindthe seats as i have used that to get into the boot.
Is this all i would need?
http://www.ebay.co.uk/itm/3804039692...ht_2999wt_1026
Old 11th May 2012, 09:22 AM
Maybe... Not sure if the seat back needs changed or not... never looked into it in a D3.
Old 3rd January 2013, 08:45 AM
Default Very simple retrofit
Just to follow up on my own question, it is a pretty easy retrofit.
All that is needed is to remove the cover trim from behind the armrest - it just pulls out from under the seat back. Pull out the soundproofing, which is already cut and reveal the hole in the bulkhead filled with a plastic filler. You can wiggle the plastic out through the front once it has been unclipped.
Then carefully cut the carpet covering the rear bulkhead using the hole as a cutting guide and push the hatch in from the boot. It just clips in just like the plastic cover that you have just removed.
Most of the used ski hatches i saw did not seem to include the trim piece that covered the front edge between the hatch and he seats, so will need to be ordered separately at huge cost if not supplied- this is the only real gothcha.
All in it probably took about 45 minutes from start to finish and well worth doing.
Old 30th May 2013, 10:14 PM
I'm retrofitting ski hatch now and there's one thing I don't understand. The hatch has a magnet from the boot side. I understand the magnet is designed to hold hatch in place when opened. But magnet doesn't work with aluminium... When hatch opens the magnet is at awkward angle to chassis so it can't engage with anything.
What that magnet is for?
Also got a part called "stop plate cover" that came with the hatch:
I don't understand where should I use that "stop plate cover". Because it is made of metal I make conclusion it should work with a magnet
Confused a bit.
Old 31st May 2013, 07:21 AM
Is there not a frame that goes with the ski hatch that would match up with the lugs on the metal bar you have?
Old 31st May 2013, 07:41 AM
david@a8parts david@a8parts is offline
Director at A8 Parts
If you take a look directly upwards from the base of the ski hatch opening in the boot (the underside of the parcel shelf in effect) there is a couple of slits in the metal where the gold piece of steel will slot into (apply a little pressure to bend it slightly so it will snap into position)
This will then line up with the magnet so that when the hatch is in use it keeps the cover up and out of the way.
Hope this helps :-)
At Work to Break:
2001 TT 8N 1.8T Quattro with a loud exhaust!
2000 A8 D2 3.7Q Non Sport Ming Blue
1999 A8 D2 4.2Q Non Sport Santorin Blue
2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather
2001 A2 1.4 TDi
2006 A6 C6 2.4 Quattro Avant Canyon Red
At Work to Drive:
1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch
1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash
2008 Fiesta Sportvan x2
2002 Transit 2.4 LWB
2007 VW Crafter Recovery Truck
2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart
2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses.
At Work to Hire:
4x 6 Berth Sunlight Motorhomes
Old 31st May 2013, 08:31 AM
No Perhaps maybe because I've got FL and the metal bar is for the pre-FL...
Old 31st May 2013, 08:33 AM
Hope this helps :-)
Yep, I knew it should be there, just don't understand where the gold piece should slot to May I ask for a picture please or would it be too much?
