Old 28th November 2013, 10:44 PM
Default [chart] Terminal connectors + PN
Just some of them which I found minute ago, hopefully you will find useful one day
I found them in following connectors:
- headlights (10 and 14 -pin connectors), headlight washers
- all 3 connectors on onboard power supply control unit J519 (10, 23, 32 -pin connectors and a lot of other Jxxx control units)
- CAN BUS separating connectors (46pin)
- fuse boxes, large, medium and small fuses
+ more
ID:	6988   Click image for larger version
Old 29th November 2013, 03:55 AM
I guess you couldn't find a supplier for the pins then?
Have you considered a scrap yard and getting a vag loom to hack plugs off.
Old 29th November 2013, 06:13 AM
Hi Del
I did mate, more info and links here http://forum.a8parts.co.uk/showthrea...4976#post64976
And I did consider a used loom, but I prefer new stuff
Old 6th December 2013, 08:25 AM
Updated common use of the listed connectors
