Old 21st April 2015, 11:03 PM
Zip's Avatar
Zip Zip is offline
Question Temp gauge not working...
Hmmm....I'm not getting any erratic behaviour at all. No change in coolant level. The gauge is just not moving.
Any ideas?
Ta in advance,
Z
Old 22nd April 2015, 08:21 AM
Faulty sensor? It has 2 parts, one feeds the electronics the other the instruments.
Old 22nd April 2015, 08:54 AM
^^^ Yep, temp sensor almost certainly.
Mine suddenly failed recently too in the same way. Engine was getting to temperature but the gauge wasn't moving.
Just make sure when you change it that the crappy plastic retaining clip is properly secured, if you don't want to spend a few hours on the hard shoulder like I did:
http://forum.a8parts.co.uk/showthread.php?t=9845
Even if the clip seems to be properly seated, I'd recommend dropping some heat-shrink tubing over it to prevent it sliding out.
PS: It's at the back of the engine. Might take a lot of wiggling and swearing to get the old one out.
Old 22nd April 2015, 09:29 AM
Tie something round the end of the clip before pushing/pulling it out, it can disappear so easily.
Old 22nd April 2015, 09:30 AM
Zip's Avatar
Zip Zip is offline
Question
OK - cheers. I read an earlier replacement thread......and am a bit worried that my fingers are too sausagey.....
Anyone got a part number please?
Ta,
Z
Old 22nd April 2015, 09:31 AM
Any old VAG spares department will have them, make sure you get the green one.
And a new clip and seal.
Wrong engine, but this lists the parts: http://forums.vwvortex.com/showthrea...one-(green-top)
