having run VCDS for the first time since February (when it was faultless), I have a number of fault codes some of which are a bit worrying:
The main issue is: Address 02: Auto Trans Labels: 01L-927-156.lbl Part No: 4D0 927 156 EC Component: AG5 01L 4.2l5V RdW 1010 Coding: 00101 Shop #: WSC 02314 VCID: 6ED8DF392A5A996E79B-5102 3 Faults Found: 18232 - Pressure Control Valve 3 (N217) P1824 - 35-10 - Open or Short to Ground - Intermittent 18227 - Pressure Control Valve 2 (N216) P1819 - 35-10 - Open or Short to Ground - Intermittent 18222 - Pressure Control Valve 1 (N215) P1814 - 35-10 - Open or Short to Ground - IntermittentI checked against RossTech Wiki and it points towards "checking connectors for corrosion or water damage, in case of 01V transmission pay special attention to 16-pin connector between valve body and wiring harness". Other faults (apart from the alarm horn - longstanding and a rear parking sensor) are: Address 15: Airbags Labels: 4D0-959-655-AI8.lbl Part No: 4D0 959 655 T Component: Airbag Front+Kopf 5001 Coding: 01417 Shop #: WSC 02313 VCID: 438E5E8D51584406C65-5102 1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4D0-919-033-MYX.lbl Part No: 4D0 919 931 PX Component: KOMBI+WEGFAHRS.VDO D42 Coding: 00483 Shop #: WSC 00048 VCID: 902421C1D0AE6F9E8B7-5102 WAUZZZ4D43N001316 AUZ7Z0A2019945 1 Fault Found: 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent Wiki says that if multiple control modules are affected it could be a common source such as battery. Appreciate any comments/suggestions here - especially with the transmission faults.
