Old 21st August 2014, 06:57 PM
Default Water storage tank (CWS) 210 gallons
Hi there
This for sure isn't a typical A8parts forum listing, but you never know, someone may actually need one, and you could save yourself some money.
So, for sale a quality CWS tank (cold water storage)
It was design for a commercial site so made from highest quality materials to comply with BS standards for educational buildings.
From new tank was cleaned every 6months. Wasn't cleaned after removing it as this and disinfection will have to be done after install anyway.
- Made from GRP
- Nominal Capacity 1195 litres (262 gallons)
- Actual Capacity 956 litres (210 gallons)
- Comes in 5 parts: cover, lid, top part, bottom part, gasket
- Minimum loft hatch size is really small for the size of the tank 440mm x 900mm. This is if you position it vertically.
- Overall dimensions: length 2060mm / height 870mm (approx. 920mm with the round lid closed) / width 895mm
If one or more wholes are on the wrong size you can either go round it with the pipework or blank them off and do new whole/s
Top cover is bolted to top part by 6 bolts (not included)
Bottom and top part is bolted as well all the way round with bolts approx. every 5'' (not included)
Original price was £1000 +VAT or £1200 +VAT, can't remember exactly.
To be collected or courier arranged (base size - 2 pallets)
£300
ID:	8785   Click image for larger version
ID:	8786   Click image for larger version
ID:	8787   Click image for larger version
