For some reason when I select my cd option and click source I only have cd ... and should have
CD TV DAB AUX 1 AUX 2 ect.. any ideas where it might have gone ? ... Ive looked on vag com all is correct and in order ? But nothing on the mmi screen ? Any help while I have vag com would be great ? Thanks |
Have you tried running the fibre optic test, maybe something simple like the optical bus is not complete. CD is in the front obviously, but everything you have in the rear is missing. What about navigation, is that working.
Assume you can 'see' the units in VCDS and an optical test works OK?
They haven't dropped into CP have they?
All ok on vag com ... no fault codes and can see them on the optical bus ... no idea what it is .. its strange they just vanished ?
You could try the age old turn it off and on again. Last time I had a problem with the MMI, I disconnected the battery for 5 mins and it was fine again straight after reconnecting. Turning off the ignition may not be enough as the MMI might not be going to full power off.
I will try that
I think it only shows CD - TV - AMI - AUX - AUX2 on there. DAB is with radio.
Since you replaced the tv module TV - AUX - AUX2 has gone which seems logical. The only question is should Digi Box show up there?
Yes because on the W12 with dvbt works perfect ?
m going to update the mmi software and hopefully that will sort it out
The option to change what sources you got was in the hidden menu I think.
I swear I seen it in there. Go in and have a look under the tuner menu.
