Old 21st January 2009, 06:48 PM
Default Transmission Sticky
Here we will post links to Transmission related solutions. This post will be edited by an Administrator when a new solution is found either within this forum or elsewhere on the Interweb.
ZF Service Centers in the UK
Online ZF Catalogue - Architex_Ma8tey (ensure you select English from language at bottom of page).
Statement from ZF concerning Gearbox oil changes vs sealed for life - found by Completelylostagain
TRANSMISSION
Parts Catalogue - CtL
Transmission Service in Germany- Ian@a8Parts via bimmerboard.com
Strip down and repair of 1 to 4 clutchpack with lots of pictires - SyncroS8
5 Speed Transmission Service - Audipages
F125 Transmission Switch Replacement- Audipages
Transmission Removal and Replacement- Audipages
Whinning Noise after filter change remedy - TozoM8 from Audiworld found by Jayzee
D2 Gearbox Oil Change using TECH-TRONIX ATS355 Machine (suckypumpysquirtythingumajig) - notorius
Gear leaver Stuck in Park - Simon Wallwork
Throttle Position Sensor TPS modification for transmission hunt - Squeeto on Audiworld
Recalibrate the Throttle - Paul W on TSN
DIFFs AND FINAL DRIVE
Transmission and Final Drives Fluid Level Checking and Filling- Audipages
Replacing the Transmission Output Flange Seals-MikkyJane
Replacing the Transmission Output Flange Seal- Audipages
Replacing the Final Drive - Rear Output Flange Seals- Audipages
Final Drive - Rear Input Seal Replacement- Audipages
Remember, if you find a solution to a problem you've had or others have posted on the web let an Admin know (PM or email) and we will add it to this sticky.
