Old 21st January 2015, 07:14 PM
carmel120 carmel120 is offline
Default would these fit a d3
http://www.gumtree.com/p/wheel-rims-...oys/1097032655
Old 21st January 2015, 07:22 PM
Well the Q7 wheel specs are:
10jx21 ET44 part number should be 4L0 601 025S (or L - only difference is colour code)
A typical D3 wheel spec in a 20" fitment is 9jx20 ET46
You will have 11mm less clearance on the inside of the wheel and an extra 15mm sticking out on the outside. THAT'S COMPARED TO THE 20" WHEEL SO IF YOU'RE ON 19s WILL BE DIFFERENT
They're going to need to be some massive tyres on those wheels! It's going to knock your speedo out quite a bit unless you go for real rubber band tyres, but I reckon they should fit
Old 22nd January 2015, 06:24 AM
I think Q7 has different PCD as well 120 or 130mm instead of 112mm
Old 22nd January 2015, 02:51 PM
must admit I didn't look at pcd. Centre bore could be different too?
Old 22nd January 2015, 03:17 PM
Yep, center bore is 71.6mm and PCD is 5x130 for Q7
For comparison, carmel120, center bore is 57.1mm and PCD is 5x112 for D3
Matt
Yes PCD on a Q7 is 5 x 130 and centre bore is 71.6
Vs
5 x 112 and 57.1 on the D3
Old 22nd January 2015, 03:48 PM
thanks guys for the help
cheers trev
