Old 5th April 2015, 08:23 AM
Fast at Fast at is offline
Default Gearbox problems
Previously had 99 facelift s8 d2 gearbox failed as I am in Spain it was difficult to get it sorted while searching for a replacement I found a mint 98 car for not much more than a gearbox replacement.
Now this one only has 100000 kms with service history ,but the gearbox is running lumpy could it be oil and filter?
Does anyone repair these boxes to last?
I hold on in there I am a huge fan of these cars and I've had a lot of high performance cars
Old 5th April 2015, 08:59 AM
You could get it serviced by ZF in Dortmund, admittedly a bit far from Spain, but looks impressive. And they did build this transmission in the first place.
http://forum.a8parts.co.uk/showthread.php?t=338
Or if faced with a £3k full rebuild, and your car is LHD, its a painful option but you could do a direct conversion to Getrag 6-speed manual with all standard factory parts. If you still have the old car you could bring that one back to life as well.
The most expensive part, the 01E transmission, is now so cheap and the 6-speed 4WD version is found in A4s and A6s. In the UK I bought a 2002 01E from a A6 TDi for just £200. Also the 01E is arguably the toughest Audi manual transmission to date.
Old 6th April 2015, 07:59 AM
Thanks for that very interesting
