Old 4th May 2015, 02:31 PM
Default Rs4 calipers and 365x34mm discs - whose done it?
As above folks,
Has anyone done this conversion to a FL S8 currently fitted with Brembo's?
Don't need an upgrade, just weighing it up as I need to refurb my existing calipers
Aside from cost, is their any reason why I shouldn't do this? Happy with current brake performance so this would largely be form/bling over function
I was thinking of using rS4 calipers with w12 Phaeton discs which are much cheaper - would these or rs4 discs be a straight swap?
Do you need adaptors and/or hoses ?
Is there a weight gain in using RS4 calipers?
Does the brake bias change with rs4 front calipers alone? Would I need to upgrade the rears to reset the bias?
I see urquattro.net via eBay has a kit for the D2 that uses rs6 calipers and what looks to be phaeton discs for £1600- I think this could be done slightly cheaper as they charge £500 for the genuine VW phaeton discs alone.
http://m.ebay.de/itm/380328707729
Apologies for all the questions, just trying to see if it's a bolt on upgrade and if so, what are the downsides (if any, apart from cost).
Shirish: 2001 S8
