Old 14th July 2015, 02:44 PM
johnny_quattro's Avatar
Default Trim discolouration inside - rear windscreen
I've just taken the decision to 'de-tint' my windows and I'm pleased with the result, as the car looks more classy and less pimp. I've now discovered that there's a circular patch of nastiness where the finish has come away at the rear of the deck, behind where the BOSE speakers are installed. It's right in the crevice so quite hard to get at so it looks like a fiddly job.
The location is where the rear windscreen meets the rear deck and it looks to be made of perforated metal and painted matt black? I will go and take a photo of it and post back here later.
Any suggestions on how to fix this and get it looking the same colour?
Old 15th July 2015, 10:24 AM
It's part of the parcel shelf, there is a strip of light foam stuck to the underside of it too from memory.
Removal of the shelf is easy enough and a mask up and rattle can of satin black would fix it if it doesn't just wipe off.
Old 15th July 2015, 12:48 PM
Default Lazy bleeder
I'm going to go for the easy option to start with, to see if I can cover it with something without taking it all apart. See photo - the reflection of the aerial points to 'X marks the spot'.
Thanks for the advice.
