As most of you know an ACC install is happening over the next few days.
So not ever having an ACC car much less an 8 with it I had no idea what works with what and what has to be done in order for it too work. The biggest thing that was bugging me was despite having the ACC comaptible gateway and distance stalk fitted to the car with various errors due to the radar not having comms was that the control head in the car refused to display the menu for adaptive cruise. That along with the fact the when it reboots it shows an S6 logo "weird" is it just my car? So today after having made a loom last night for the radar sensor I wanted to test the radar supplied by Dave at A8 parts ![]() Prior to fitting the radar there was no end of faults logged because i had coded all the modules for ACC but radar was still missing. Happily once i connected the radar to the gateway and supplied power it immediately was apparent in the menu because adaptive cruise appeared at the top of the list ![]() Anyway i digress, once the radar was in place i cleared all the codes to see what was remaining and needed attention see attachments I then disconnected the radar and scanned again and you can see a whole host of errors that exist because comms to the radar is missing. There is also a fault logged for left hand headlight saying no signal, that was because i had the fuse out. The airbag fault was because the glovebox was removed. Code:
Repair Order: interesting -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1D 1E 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77 VIN: WAUZZZ4E77N009165 Mileage: 105450km-65523miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: Malfunction 0010 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Cannot be reached 1100 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: OK 0000 6C-Back-up Cam. -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI ™0060 Revision: 5AH11--- Serial number: AUX3Z0F8307595 Coding: 01060003190F0260 Shop #: WSC 00586 210 91538 VCID: 5FCD4C658E49DCD9375-800A 2 Faults Found: 049717 - No Communications with Cruise Control (Front) Distance Sensor U0235 - 001 - Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 105453 km Time Indication: 0 Date: 2015.08.05 Time: 15:03:21 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 76.0∞C Temperature: 57.0∞C Absolute Pres.: 1000.0 mbar Voltage: 11.938 V 006435 - Please Check DTC Memory of ECU Number 2 P1923 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 105453 km Time Indication: 0 Date: 2015.08.05 Time: 15:03:22 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 76.0∞C Temperature: 57.0∞C Absolute Pres.: 1000.0 mbar Voltage: 11.938 V Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 K HW: 09E 927 156 B Component: AG6 09E 5,2 FSI RdW 0020 Revision: --H01--- Serial number: 0093558 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2B55E8B58A717079EBD-807E 1 Fault Found: 006273 - Powertrain Data Bus: Missing Message P1881 - 000 - Acceleration Request Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 105453 km Time Indication: 0 Date: 2015.08.05 Time: 14:05:05 Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min (no units): 30.0 (no units): 157.0 Temperature: 55.0∞C T.B. Angle: 0.0∞ ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB Component: ESP 5.7 allrad H46 0500 Coding: 0001927 Shop #: WSC 02313 000 00000 VCID: 24470389E7AFBF012A7-8071 1 Fault Found: 02083 - Message for Delay Request 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0F8307595 Coding: 0412672 Shop #: WSC 02313 785 00200 VCID: 58BF6779EB672BE176F-800D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 02313 785 00200 VCID: 24470389E7AFBF012A7-8071 2 Faults Found: 01733 - Switch for Head-Rest Adj. Pass. Seat (E170); Down 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 4 Fault Frequency: 1 Reset counter: 27 Mileage: 105452 km Time Indication: 0 Date: 2015.08.05 Time: 14:36:20 01732 - Switch for Head-Rest Adj. Pass. Seat (E170); Up 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 4 Fault Frequency: 1 Reset counter: 27 Mileage: 105452 km Time Indication: 0 Date: 2015.08.05 Time: 14:36:20 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 732 L HW: 4E0 035 729 A Component: Interfacebox H43 3460 Revision: 00000000 Serial number: 300IL067573450 Coding: 0010002 Shop #: WSC 00000 000 08192 VCID: 2B55E8B58A717079EBD-807E Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH03 0040 Subsystem 2 - Serial number: 00000000019844 Subsystem 3 - Serial number: 0117.08.060000000100010094ˇ Subsystem 4 - Serial number: 010094ˇ 2 Faults Found: 01319 - Control Module for Distance Control (J428) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 242 Mileage: 105453 km Time Indication: 0 Date: 2015.08.05 Time: 14:05:48 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 6 Reset counter: 40 Mileage: 105453 km Time Indication: 0 Date: 2015.08.05 Time: 14:44:04 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000106345 Coding: 0057465 Shop #: WSC 02313 785 00200 VCID: 1C373B69DFDF87C1927-8049 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q Component: ILM Fahrer H15 0230 Coding: 0133121 Shop #: WSC 02313 785 00200 VCID: 3663C9C141333D91843-8063 Subsystem 1 - Part No: 4E2 910 113 C Component: Wischer WWS D3 H60 0440 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH13 0090 Coding: 00141886 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 B HW: 4E0 035 785 B Component: SG ext.Player H09 0700 Revision: 00000000 VCID: 275D1485569954190F5-8072 No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: None Part No SW: 4E0 910 563 C HW: 4E0 035 563 Component: DAB-Tuner H41 0830 Revision: 00000001 Serial number: KE1276U7400564 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 24470389E7AFBF012A7-8071 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI ™0060 Revision: 5AH11--- Serial number: AUX3Z0F8307595 Coding: 01060003190F0260 Shop #: WSC 00586 210 91538 VCID: 5FCD4C658E49DCD9375-800A 1 Fault Found: 049717 - No Communications with Cruise Control (Front) Distance Sensor U0235 - 001 - Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 6 Reset counter: 255 Mileage: 105453 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 100.0∞C Temperature: 62.0∞C Absolute Pres.: 1000.0 mbar Voltage: 11.938 V ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H13 3710 Revision: 91H13371 Serial number: 0037P0G02C1N Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 275D1485969954190F5-8072 Subsystem 1 - Serial number: 63328RB40180B9CAT Subsystem 2 - Serial number: 63428RB40180B95FS Subsystem 3 - Serial number: 63528RB40180B9CCX Subsystem 4 - Serial number: 63628RB40180B95ET Subsystem 5 - Serial number: 63729RB401A1D1B6Q Subsystem 6 - Serial number: 63829RB401A2165DM 2 Faults Found: 01228 - Airbag Cut-Off Switch for Passenger Side (E224) 010 - Open or Short to Plus - Intermittent - MIL ON Freeze Frame: Fault Status: 10101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 105453 km Time Indication: 0 Date: 2015.08.05 Time: 13:46:43 02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224) 010 - Open or Short to Plus - Intermittent - MIL ON Freeze Frame: Fault Status: 10101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 105453 km Time Indication: 0 Date: 2015.08.05 Time: 13:46:43 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenks‰ulenmodul H14 0040 Coding: 0112151 Shop #: WSC 02313 785 00200 VCID: 65C15E8DAC158609FD9-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 951 E HW: 4E0 920 951 E Component: KOMBIINSTR. VDO H82 0520 Revision: D03 Serial number: AUDID3F8000540 Coding: 0048403 Shop #: WSC 03329 002 104857 VCID: 275D1485969954190F5-8072 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.lbl Part No SW: 4L0 910 468 A HW: 4E0 907 468 H Component: J533__Gateway H06 0060 Revision: 00H06000 Serial number: 0100J075308013 Coding: F5F5DFFF717E1E00 Shop #: WSC 02313 758 00200 VCID: 2D51E6ADB4657E49F59-8078 2 Faults Found: 02001 - Data-Bus Automatic Distance Regulation 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 1 Fault Frequency: 4 Reset counter: 242 Mileage: 105453 km Time Indication: 0 Date: 2015.08.05 Time: 14:05:06 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 26 Mileage: 105453 km Time Indication: 0 Date: 2015.08.05 Time: 14:44:28 ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 A HW: 4E2 905 218 B Component: FPI_1 H01 0020 Revision: 01000102 Serial number: 22082006152159 Shop #: WSC 00000 000 00000 VCID: 1F4D0C65CEC99CD9775-804A No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBF8200979 Shop #: WSC 00000 000 00000 VCID: 1C373B69DFDF87C1927-8049 No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 C Component: KLIMA-STG. FOND 017 0230 Revision: 00000019 Serial number: 00000000046196 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 61C94A9DB83DEA29011-8034 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: User\TEST-34.lbl Part No SW: 4E0 910 553 J HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 6310 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2A5BEDB1858B697110B-807F No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063342 Shop #: WSC 02313 785 00200 VCID: 24470389E7AFBF012A7-8071 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 D Component: MNS ECE H48 1060 Revision: 00000000 Serial number: 364I.067595623 Shop #: WSC 02313 785 00200 VCID: 3B75D8F57A11E0F97BD-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H05 0090 Serial number: 00000625800101 Coding: 0036068 Shop #: WSC 02313 785 00200 VCID: 1D31366DC4C58EC9659-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 D Component: T¸rsteuer.FS BRM005 0180 Coding: 0032751 Shop #: WSC 02313 785 00200 VCID: 204F0F99F3B7A3214EF-8075 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 D HW: 4E0 907 289 D Component: Komfortgeraet H07 0010 Revision: 00100007 Serial number: W040609220062 Coding: 0004861 Shop #: WSC 02313 785 00200 VCID: 2A5BEDB1858B697110B-807F Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H05 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: None Part No SW: 4E0 910 466 B HW: 4E0 035 466 Component: BO_D3 H06 0180 Revision: 20S00002 Serial number: 01109060005185 Coding: 0000027 Shop #: WSC 02313 785 00200 VCID: 25411E8DEC9546093D9-8070 Subsystem 1 - Part No: 4E0 910 465 A Component: BO_D3_SLAVE H31 0100 Subsystem 2 - Serial number: 01809060002932 Subsystem 3 - Serial number: 0218.09.060000000100030011ˇ Subsystem 4 - Serial number: 030011ˇ No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 B Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000001772 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E333161C9C395D17C3-804B No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 D Component: T¸rsteuer.BF BRM005 0180 Coding: 0032751 Shop #: WSC 02313 785 00200 VCID: 204F0F99F3B7A3214EF-8075 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0000731 Shop #: WSC 00019 210 80940 VCID: 1F4D0C65CEC99CD9775-804A No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 00019 210 90927 VCID: 295912BD808D6269191-807C Subsystem 1 - Part No: 4F0 941 329 D Component: AFS-Modul links H01 0010 Subsystem 2 - Part No: 4F0 941 329 D Component: AFS-Modul rechtsH02 0020 1 Fault Found: 02233 - Left Headlight Power Output Stage (J667) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 40 Mileage: 105448 km Time Indication: 0 Date: 2015.08.05 Time: 14:05:05 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 Q HW: 4E0 035 541 P Component: TUNER EU/US/RDW H42 0620 Revision: 00000000 Serial number: 396I+067546743 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2E53E1A1B9630551CC3-807B No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 B HW: 4E0 919 148 Component: R0078 TVhybridTuner 0360 Revision: R0H05000 Serial number: 76300700573201 Coding: 0000003 Shop #: WSC 02313 785 00200 VCID: 224B0591FDBBB13158B-8077 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000020865 Shop #: WSC 00000 128 00289 VCID: 204F0F99F3B7A3214EF-8075 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 1121910408 Coding: 344530393135313035412056413031313231393130343038 Shop #: WSC 00000 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: T¸rsteuer.HL BRM005 0180 Coding: 0032751 Shop #: WSC 02313 785 00200 VCID: 1E333161C9C395D17C3-804B No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 A HW: 4F0 907 273 A Component: Reifendruck 3 H05 Revision: 00050340 Serial number: 00000900047805 Coding: 0212329 Shop #: WSC 02313 785 00200 VCID: 204F0F99F3B7A3214EF-8075 No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000610040141 Shop #: WSC 12336 024 394758 VCID: 3663C9C141333D91843-8063 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4L0-910-441.clb Part No SW: 4E0 910 441 HW: 4L0 907 441 A Component: J772__Rearview 0050 Revision: --H12--- Serial number: 525PA8-J07100I Coding: 1121402 Shop #: WSC 98765 666 38384 VCID: 5CB77B699F5FC7C1527-8009 1 Fault Found: 03006 - Back-up Camera System not calibrated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 242 Time Indication: 0 Freeze Frame: Invalid Invalid Invalid ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 D Component: T¸rsteuer.HR BRM005 0180 Coding: 0032751 Shop #: WSC 02313 785 00200 VCID: 1E333161C9C395D17C3-804B No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08720624801512 Coding: 0321008 Shop #: WSC 02313 785 00200 VCID: 23450095E2A1B83953D-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 M HW: 4E0 862 335 Component: Handyvorb2 H13 1130 Revision: 00000000 Serial number: 00000007580460 Coding: 0010900 Shop #: WSC 00019 210 80940 VCID: 2C57EBA98F7F7741E27-8079 No fault code found. End-------------------------(Elapsed Time: 04:09)-------------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 17: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 02: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 03: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 05: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 06: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 07: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 08: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 09: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 0E: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 0F: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 11: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 15: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 16: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 19: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 1D: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 1E: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 28: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 34: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 36: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 37: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 38: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 42: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 46: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 47: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 4F: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 52: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 53: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 55: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 56: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 57: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 61: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 62: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 65: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 67: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 6C: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 72: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 76: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 77: DTCs cleared Code:
Repair Order: ACC instal -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1D 1E 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77 VIN: WAUZZZ4E77N009165 Mileage: 105450km-65523miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: OK 0000 6C-Back-up Cam. -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI ™0060 Revision: 5AH11--- Serial number: AUX3Z0F8307595 Coding: 01060003190F0260 Shop #: WSC 00586 210 91538 VCID: 5FCD4C658E49DCD9375-800A No fault code found. Readiness: 0110 1001 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 K HW: 09E 927 156 B Component: AG6 09E 5,2 FSI RdW 0020 Revision: --H01--- Serial number: 0093558 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2B55E8B58A717079EBD-807E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB Component: ESP 5.7 allrad H46 0500 Coding: 0001927 Shop #: WSC 02313 000 00000 VCID: 24470389E7AFBF012A7-8071 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0F8307595 Coding: 0412672 Shop #: WSC 02313 785 00200 VCID: 58BF6779EB672BE176F-800D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 02313 785 00200 VCID: 24470389E7AFBF012A7-8071 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 732 L HW: 4E0 035 729 A Component: Interfacebox H43 3460 Revision: 00000000 Serial number: 300IL067573450 Coding: 0010002 Shop #: WSC 00000 000 08192 VCID: 2B55E8B58A717079EBD-807E Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH03 0040 Subsystem 2 - Serial number: 00000000019844 Subsystem 3 - Serial number: 0117.08.060000000100010094ˇ Subsystem 4 - Serial number: 010094ˇ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000106345 Coding: 0057465 Shop #: WSC 02313 785 00200 VCID: 1C373B69DFDF87C1927-8049 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q Component: ILM Fahrer H15 0230 Coding: 0133121 Shop #: WSC 02313 785 00200 VCID: 3663C9C141333D91843-8063 Subsystem 1 - Part No: 4E2 910 113 C Component: Wischer WWS D3 H60 0440 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH13 0090 Coding: 00141886 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBF8200979 Shop #: WSC 00000 000 00000 VCID: 1C373B69DFDF87C1927-8049 No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: None Part No SW: 4E0 910 563 C HW: 4E0 035 563 Component: DAB-Tuner H41 0830 Revision: 00000001 Serial number: KE1276U7400564 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 24470389E7AFBF012A7-8071 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI ™0060 Revision: 5AH11--- Serial number: AUX3Z0F8307595 Coding: 01060003190F0260 Shop #: WSC 00586 210 91538 VCID: 5FCD4C658E49DCD9375-800A No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: None Part No SW: 4E0 910 561 F HW: 4E0 907 561 F Component: ABSTANDSREGELUNGH03 0020 Coding: 0041255 Shop #: WSC 00029 210 86049 VCID: 25411E8DEC9546093D9-8070 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H13 3710 Revision: 91H13371 Serial number: 0037P0G02C1N Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 275D1485969954190F5-8072 Subsystem 1 - Serial number: 63328RB40180B9CAT Subsystem 2 - Serial number: 63428RB40180B95FS Subsystem 3 - Serial number: 63528RB40180B9CCX Subsystem 4 - Serial number: 63628RB40180B95ET Subsystem 5 - Serial number: 63729RB401A1D1B6Q Subsystem 6 - Serial number: 63829RB401A2165DM 2 Faults Found: 01228 - Airbag Cut-Off Switch for Passenger Side (E224) 010 - Open or Short to Plus - MIL ON Freeze Frame: Fault Status: 11101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 105453 km Time Indication: 0 Date: 2015.08.05 Time: 13:46:43 02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224) 010 - Open or Short to Plus - MIL ON Freeze Frame: Fault Status: 11101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 105453 km Time Indication: 0 Date: 2015.08.05 Time: 13:46:43 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenks‰ulenmodul H14 0040 Coding: 0112151 Shop #: WSC 02313 785 00200 VCID: 65C15E8DAC158609FD9-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 951 E HW: 4E0 920 951 E Component: KOMBIINSTR. VDO H82 0520 Revision: D03 Serial number: AUDID3F8000540 Coding: 0048403 Shop #: WSC 03329 002 104857 VCID: 275D1485969954190F5-8072 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.lbl Part No SW: 4L0 910 468 A HW: 4E0 907 468 H Component: J533__Gateway H06 0060 Revision: 00H06000 Serial number: 0100J075308013 Coding: F5F5DFFF717E1E00 Shop #: WSC 02313 758 00200 VCID: 2D51E6ADB4657E49F59-8078 No fault code found. ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 A HW: 4E2 905 218 B Component: FPI_1 H01 0020 Revision: 01000102 Serial number: 22082006152159 Shop #: WSC 00000 000 00000 VCID: 1F4D0C65CEC99CD9775-804A No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R192) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 B HW: 4E0 035 785 B Component: SG ext.Player H09 0700 Revision: 00000000 VCID: 275D1485569954190F5-8072 No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 C Component: KLIMA-STG. FOND 017 0230 Revision: 00000019 Serial number: 00000000046196 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 61C94A9DB83DEA29011-8034 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: User\TEST-34.lbl Part No SW: 4E0 910 553 J HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 6310 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2A5BEDB1858B697110B-807F No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063342 Shop #: WSC 02313 785 00200 VCID: 24470389E7AFBF012A7-8071 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 D Component: MNS ECE H48 1060 Revision: 00000000 Serial number: 364I.067595623 Shop #: WSC 02313 785 00200 VCID: 3B75D8F57A11E0F97BD-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H05 0090 Serial number: 00000625800101 Coding: 0036068 Shop #: WSC 02313 785 00200 VCID: 1D31366DC4C58EC9659-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 D Component: T¸rsteuer.FS BRM005 0180 Coding: 0032751 Shop #: WSC 02313 785 00200 VCID: 204F0F99F3B7A3214EF-8075 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 D HW: 4E0 907 289 D Component: Komfortgeraet H07 0010 Revision: 00100007 Serial number: W040609220062 Coding: 0004861 Shop #: WSC 02313 785 00200 VCID: 2A5BEDB1858B697110B-807F Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H05 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: None Part No SW: 4E0 910 466 B HW: 4E0 035 466 Component: BO_D3 H06 0180 Revision: 20S00002 Serial number: 01109060005185 Coding: 0000027 Shop #: WSC 02313 785 00200 VCID: 25411E8DEC9546093D9-8070 Subsystem 1 - Part No: 4E0 910 465 A Component: BO_D3_SLAVE H31 0100 Subsystem 2 - Serial number: 01809060002932 Subsystem 3 - Serial number: 0218.09.060000000100030011ˇ Subsystem 4 - Serial number: 030011ˇ No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 B Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000001772 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E333161C9C395D17C3-804B No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 D Component: T¸rsteuer.BF BRM005 0180 Coding: 0032751 Shop #: WSC 02313 785 00200 VCID: 204F0F99F3B7A3214EF-8075 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0000731 Shop #: WSC 00019 210 80940 VCID: 1F4D0C65CEC99CD9775-804A No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 00019 210 90927 VCID: 295912BD808D6269191-807C Subsystem 1 - Part No: 4F0 941 329 D Component: AFS-Modul links H01 0010 Subsystem 2 - Part No: 4F0 941 329 D Component: AFS-Modul rechtsH02 0020 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 Q HW: 4E0 035 541 P Component: TUNER EU/US/RDW H42 0620 Revision: 00000000 Serial number: 396I+067546743 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2E53E1A1B9630551CC3-807B No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 B HW: 4E0 919 148 Component: R0078 TVhybridTuner 0360 Revision: R0H05000 Serial number: 76300700573201 Coding: 0000003 Shop #: WSC 02313 785 00200 VCID: 224B0591FDBBB13158B-8077 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000020865 Shop #: WSC 00000 128 00289 VCID: 204F0F99F3B7A3214EF-8075 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 1121910408 Coding: 344530393135313035412056413031313231393130343038 Shop #: WSC 00000 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: T¸rsteuer.HL BRM005 0180 Coding: 0032751 Shop #: WSC 02313 785 00200 VCID: 1E333161C9C395D17C3-804B No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 A HW: 4F0 907 273 A Component: Reifendruck 3 H05 Revision: 00050340 Serial number: 00000900047805 Coding: 0212329 Shop #: WSC 02313 785 00200 VCID: 204F0F99F3B7A3214EF-8075 No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000610040141 Shop #: WSC 12336 024 394758 VCID: 3663C9C141333D91843-8063 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4L0-910-441.clb Part No SW: 4E0 910 441 HW: 4L0 907 441 A Component: J772__Rearview 0050 Revision: --H12--- Serial number: 525PA8-J07100I Coding: 1121402 Shop #: WSC 98765 666 38384 VCID: 5CB77B699F5FC7C1527-8009 1 Fault Found: 03006 - Back-up Camera System not calibrated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 242 Time Indication: 0 Freeze Frame: Invalid Invalid Invalid ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 D Component: T¸rsteuer.HR BRM005 0180 Coding: 0032751 Shop #: WSC 02313 785 00200 VCID: 1E333161C9C395D17C3-804B No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08720624801512 Coding: 0321008 Shop #: WSC 02313 785 00200 VCID: 23450095E2A1B83953D-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 M HW: 4E0 862 335 Component: Handyvorb2 H13 1130 Revision: 00000000 Serial number: 00000007580460 Coding: 0010900 Shop #: WSC 00019 210 80940 VCID: 2C57EBA98F7F7741E27-8079 No fault code found. End-------------------------(Elapsed Time: 04:06)--------------------------
Del ![]() Last edited by Delboy; 17th August 2015 at 11:16 AM. |
Excellent post Del, very informative
