Old 29th August 2015, 03:18 PM
mark_le_b mark_le_b is offline
Default S8 D2 glass sunroof adjustment??
Hello all
The rear of my glass sunroof is sitting low - ie not flush with the roof - any idea if it can be adjusted to fit properly flush
It opens and closes ok - but have had a small leak and this and blocked drains may not have helped, so hope there is away to make it fit better!
Thanks
Old 29th August 2015, 04:26 PM
Yes it can. I'll dig out the reference which is in the Tech Dump.
Old 29th August 2015, 04:28 PM
Its in the Manual on General Body Assembly Exterior page 125.
Old 29th August 2015, 04:33 PM
Thanks for that
Old 30th August 2015, 05:58 AM
But it's a 2 man job isn't it David?
Old 30th August 2015, 07:58 AM
One inside, one outside to check level??
Old 30th August 2015, 08:36 AM
Exactly. The requirement to have the leading edge ~0-1mm below and the trailing edge ~0-1mm above the roof level requires the outside person to hold the sunroof in place /check the levels as the person inside tightens the screws.
Old 30th August 2015, 10:17 AM
Thanks for that, will give it a go - just have to fathom hoe to get the headliner off the sunroof to expose the bolts
Old 30th August 2015, 02:50 PM
Open the sunroof about half way. Pop the 2 plastic clips at the front and then push the headlining backwards.
Old 30th August 2015, 04:00 PM
great, thanks
