i am looking at pagid front and rear pads from ECP the front being the 8 pad set. i presume pad selection is not difficult…
but which discs do i need. as there seems to be 2 sizes .. i am running standard the 17inch alloy many thanks raj |
IIRC the Quattro Sport has different brake setup to the non sport version, but cannot say what goes with what.
Well, 345mm discs are for S8 Brembos.
Which PR code do you have out of:
1LJ 1LX 1ZL As that will determine which parts you need (this is often quoted when you look at the detailed info on the parts offered by ECP) Adrian
323x30 for the facelift D2 with 4-pad calipers
![]() Pre-facelift had 314mm for non-sport and FWD versions. |
would that be 323 x 30 front and rear?
many thanks for the guidance. raj Last edited by goldsax; 8th January 2016 at 09:56 PM. |
Rear is a lot smaller, read here.
http://forum.a8parts.co.uk/showthread.php?t=7739
I find the Brembo site v useful and it appears to show all models/variants and gives the make and size etc of the discs/pads. See link below:
http://www.bremboaftermarket.com/En/...ueBrand=Brembo
