Have any members had their ABS unit rebuilt, specifically the electronic half? Who did you use?
ABS Lights are on and there's no VCDS communication, the last retrieved fault code was 01203 - Electrical Connection between ABS and Instrument Cluster 03-10 - No Signal – Intermittent Searching tells me this is a generic Bosch part used in various VAG cars including the A4 B5 and A8 D2 and this type of failure is well know that there is even a rebuild kit from the Dealer. However, I've found this company and the price seems ok. http://www.ebay.co.uk/itm/Audi-A4-AB...-/400442033788 Used ABS units are slightly more expensive and may have the same problem. Other than above there is also the DIY route which seems a bit crude by cutting into the case. http://www.cardiagnostics.be/-now/ABS%20VW%20Passat.htm
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 21st February 2016 at 08:01 PM. |
I had an issue about a year ago, took my unit off and sent it to BBA reman - another such company in the SE who after a week or so told me that the unit was un-repairable and still charged me £40 for testing and time, so just be prepared for that possible reply when you do put yours in. Thats why I went with a second hand unit in the end but they must be a matched pair (there are many codes/pairs but dont get into thinking you can swap the ecu with another so that you dont have to take the abs unit off unless its the same code exactly)
![]() If you do get it fixed I also recommend getting hold of some heat shield material and trying to mask off the ABS unit from the exhaust/engine area with it as much as possible. It is thought that the heat from the engine and exhaust is what eventually breaks down the solder joints etc in the ecu over time so you may want to better protect it once fixed (I have)
Confidence is the feeling you have before you know better . . . . ![]() Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble ![]() Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble ![]() Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs Last edited by Architex_mA8tey; 21st February 2016 at 08:42 PM. |
Thanks Neil for that excellent reply
![]() Since both halves should match did you replace the whole unit including hydraulic block? Potentially replacing with a used unit seems top option for now. Did you do this yourself? I'll check Elsa to see what's involved and if I should do the work myself. Thanks again.
second hand units seem to go from £160-£250 from what I've seen. David sometimes has them at A8 Parts. Failing that I think we might have at least 1 second hand unit laying around this end as a spare if you cant find one elsewhere.
Cheers Neil. I'll take a look at the actual unit to read the Bosch and Audi part number. Hopefully there's a matching second hand unit out there
the replacement unit doesn't have to have matching numbers to yours but then you have to replace the whole unit, whereas if it is matching then you could in theory separate off the ECU and just change that bit, so dont panic too much if whats out there for sale doesn't match, just change the whole unit and bleed the brakes
I had a similar carry on with BBA reman. Never again.
I would recommend http://www.actronics.eu/en My friend used them and said they were very helpful ![]() |
If buying a used replacement, it's worth noting the hydraulic side has a limited time it can be sitting removed from a car, with no hydraulic fluid in it. After a month or so isolated from the hydraulic circuit, a very fine layer of corrosion forms in the solenoid valve bores, causing them to stick. In bad weather, they could deteriorate even faster.
I would advise you buy used from a seller who either still has the unit fitted to a car, and remove it yourself. Or a trusted seller who can assure you it has just been removed. This does not apply to cars that have been sitting around for a year, with the calipers missing, and all the fluid drained.
2006 Audi A8 D3 Quattro Sport 4.2 TDI - Silver, Family Oil Burner. 2000 Audi A4 Quattro Sport 2.5 TDI - Santorin Blue, S8-Powered DTM Race Car Build In Progress. 2000 Audi A4 Quattro Sport 2.8 30V - Pelican Blue, RS4 Widebody, D3 4.2 01E, High-Spec B5 Build In Progress. |
The ones I have bought in the past have come with fluid still inside,pipes still attached just cut off, ends flattened and folded over. So I guess it depends on breaker, if they know what they are doing they will remove it such way so that it can be stored for long time.
