Old 24th June 2015, 11:12 AM
barzya8 barzya8 is offline
Default Cruise Control Module
Hi Guys,
Hoping someone can help me locate this.
I have a Pre FL, so the vacuum type unit
I have followed all the threads on here showing possible location, for example.
1. Right hand side of engine bay, where the Engine ECU and gearbox TCU sit.
2. Behind the glove box inside the car.
Neither place has the cruise control box visable.
My thought process now is that it maybe underneath either the Engine ECU or the Gearbox TCU.
Looking at IT Administrators post of inside the Plenum Chamber, where he takes the gearbox TCU unit out and the ABS/ESP ECU unit, there does not appear to be any other unit in there.
Before progressing further I would appreciate anyone advise on this.
Thanks,
David
Guildford, Surrey
Bose sound system.
Audi Navigation Plus.
20 inch Final Edition alloys
Old 24th June 2015, 11:16 AM
It is DEFINITELY inside the ECU box under the bonnet, nearside near the bulkhead on RHD.
I replaced mine (bought one from A8parts of course) a few years back but got my local VAG independent to do it as it's right at the bottom and all the other ECU's have to come out first! Beyond my pay grade that.
LHD is a bit different and easier to get at, but in the same box.
Old 24th June 2015, 11:34 AM
Thanks HP Sauce,
Can you confirm if its under the Engine ECU or the Gearbox TCU, so that I don't have to pull it all out?
Guildford, Surrey
Bose sound system.
Old 24th June 2015, 01:03 PM
Sorry, no, you just need to pull them out in turn. I didn't do it myself as I couldn't see it with the cover off.
Old 25th July 2015, 12:28 AM
Originally Posted by barzya8 View Post
Thanks HP Sauce,
Where cruise is optionally fitted, it lives in the very bottom of the plenum chamber underneath the TCU and ECU. The box is tapered, narrower at the bottom so the smaller Cruise ECU fits in the there quite nicely.
If any moisture has ever made it into the chamber, gravity helpfully makes sure that the cruise module gets the brunt of it. On the plus side, issues with TCU and ECU's are very rare indeed
Pulling the modules out looks daunting but is actually pretty easy. 2 minute job.
Old 5th January 2016, 03:50 AM
RacingR RacingR is offline
Ahh search function worked
I just followed this thread http://forums.quattroworld.com/a8/th...96.phtml#19665 .... and yep, RHD are definitely different, and the otherside I could only see the ECU's ... so its buried under them?
I'll give it a go
Aussie!
Current Rides
1997 D2 A8 4.2L Quattro
1997 E38 740iL 4.4L
1998 Subaru Liberty Blistien Edition
Previous
1972 Chevrolet Camaro, 671 fed 385cu
1996 E39 523i
1997 E39 528i
2000 GXE10 IS200
2003 Alfa 147 Twinspark
Old 5th January 2016, 06:57 AM
Found it, ... pic for RHD owners reference.
Now to fix
Aussie!
Current Rides
1997 E38 740iL 4.4L
Previous
1996 E39 523i
1997 E39 528i
2000 GXE10 IS200
Old 13th June 2016, 12:17 AM
Daz 70 Daz 70 is offline
Default Cruise - Repair
Mine went duff a good few years back, it's started by just dropping the cruise as you was going along...... resetting (cycle the switch to off on the stalk) (would fix it) but got worse and worse till didn't work at all.
I used a guide just like that one basically involved re-flowing the solder on 3 caps (maybe?) and have to say mine has never missed a beat since....
Perfect.
So did you fit yours in the end
Daz
Old 13th June 2016, 11:57 AM
Thanks HP Sauce,
It is buried at the bottom, underneath both. Removing the ECU's is really very easy, couple of screws and some multiplug connectors.
The Cruise ECU is much smaller, and lives in the bottom of the chamber, so may not be immediately obvious until you remove the other modules.
