I've swapped my 4E0 919 283 A module for a 4E0 919 283 C module in my 2003 D3.
I checked module 76 coding and it was already showing a 2 for the second digit. All of the other coding for the unit was good too but I can't remember it all off hand. The sensors are working but I'm not getting the display on the dash. My MMI is at the highest level. Is there something else I need to code or enable in the MMI? Thanks David |
In the settings for the parking sensors should be an option for the display type on the MMI
I can't find any other settings for the MMI. I have the MMI hidden menu enabled and I can't find anything in there. My parking module coding is: 0201108
![]() My MMI is at software version 5570. I've been through the 3 software update CDs again and all reported no updates required. I've performed an mmi soft reset too. My VCDS logs are: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 72 76 77 VIN: WAUZZZ4E03N004951 Mileage: 102350km/63597miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: Malfunction 0010 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Sporadic communication error 1000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 4E0 910 560 D HW: 4E0 907 560 Component: 3.7L V8/5V G 0060 Revision: 00000000 Serial number: AUX3Z0BD106427 Coding: 0011773 Shop #: WSC 02312 785 00200 VCID: 224B0C03FD3A2A0EA27-8077 1 Fault Found: 18284 - Valve for Torque Support Mount P1876 - 004 - Open Circuit Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 A HW: 09E 927 156 Component: AG6 09E 3,7L5V RdW 0060 Coding: 0000001 Shop #: WSC 02312 785 00200 VCID: 204F060BF336381EB43-8075 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 A HW: 4E0 614 517 E Component: ESP 5.7 allrad H29 0400 Coding: 0008597 Shop #: WSC 02313 000 00000 VCID: 2149030FF83C3116BBD-8074 1 Fault Found: 00526 - Brake Light Switch-F 011 - Open Circuit - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H01 0070 Revision: 00703201 Serial number: AUX3Z0BD106427 Coding: 0264192 Shop #: WSC 02311 785 00200 VCID: D8BFEEEB6BE630DE0C3-808D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 1 Fault Found: 00172 - Key 2 not learned 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 5 Fault Frequency: 2 Reset counter: 50 Mileage: 164176 km Time Indication: 0 Date: 2015.04.24 Time: 12:07:58 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 B HW: 4E0 959 760 Component: Sitzmemory BFS H05 0020 Revision: 00000000 Serial number: 5DS 008 795-02 Coding: 3670016 Shop #: WSC 02311 785 00200 VCID: 224B0C03FD3A2A0EA27-8077 3 Faults Found: 01877 - Belt Height Adjustment Button (E333); Down 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 4 Fault Frequency: 1 Reset counter: 66 Mileage: 33444 km Time Indication: 0 Date: 2015.05.05 Time: 07:25:42 01876 - Belt Height Adjustment Button (E333); Up 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 4 Fault Frequency: 1 Reset counter: 66 Mileage: 33444 km Time Indication: 0 Date: 2015.05.05 Time: 07:25:42 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 14 Reset counter: 36 Mileage: 0 km Time Indication: 0 Date: 2002.01.01 Time: 00:00:00 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300LL027513709 Coding: 0000002 Shop #: WSC 59152 001 1048576 VCID: 3A7BD46375AA42CE9A7-806F Subsystem 1 - Part No: 4E0 910 609 Component: Bedienteil MMI H41 0010 Subsystem 2 - Serial number: 322KK027502509 Subsystem 3 - Serial number: ÿÿ12.11.02ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 A Component: KLIMAAUTOMAT 011 0190 Revision: 00000009 Serial number: 00000000007827 Coding: 0020545 Shop #: WSC 02311 785 00200 VCID: DABBF4E315EA22CE3A7-808F 6 Faults Found: 01087 - Basic Setting Not Performed 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 20 Mileage: 147941 km Time Indication: 0 Date: 2014.09.04 Time: 14:47:24 01592 - Air Quality Sensor (G238) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 7 Reset counter: 35 Mileage: 162661 km Time Indication: 0 Date: 2015.03.13 Time: 09:18:09 Freeze Frame: Temperature: 17.0°C 00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 9 Reset counter: 64 Mileage: 163111 km Time Indication: 0 Date: 2015.03.25 Time: 16:52:29 Freeze Frame: Voltage: 13.70 V (no units): 72.0 (no units): 255.0 00020 - Motor for Blocking Flap; Defrost and Body Vents; Right (V199) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 2 Reset counter: 68 Mileage: 164563 km Time Indication: 0 Date: 2015.05.06 Time: 07:27:26 Freeze Frame: Voltage: 13.10 V Temperature: 10.0°C (no units): 72.0 (no units): 75.0 Temperature: -90.0°C 00728 - Potentiometer in Positioning Motor for Left-Hand Central Vent (G136) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 42 Mileage: 164008 km Time Indication: 0 Date: 2015.04.20 Time: 07:27:33 Freeze Frame: Voltage: 13.50 V (no units): 0.0 (no units): 0.0 00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 61 Mileage: 164451 km Time Indication: 0 Date: 2015.05.01 Time: 07:35:06 Freeze Frame: Voltage: 13.70 V (no units): 216.0 (no units): 254.0 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 A HW: 4E0 907 279 A Component: ILM Fahrer H11 0070 Coding: 0010001 Shop #: WSC 02311 785 00200 VCID: 264310139112D62ECEF-8073 Subsystem 1 - Part No: 4E2 910 113 Component: Wischer WWS D3 H30 0310 Coding: 00000036 Shop #: WSC 02311 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 Component: Airbag 8.4E+ H08 0840 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: E3C5C90722A0E306691-80B6 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H08 0020 Coding: 0112141 Shop #: WSC 02311 785 00200 VCID: E5C1D71F2C949D36875-80B0 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H02 0050 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 950 C Component: KOMBIINSTR. VDO H38 0020 Revision: 992703 Serial number: AUDID3BD000608 Coding: 0000403 Shop #: WSC 00185 067 57207 VCID: DCB7F2FB1FDEDCFE28B-8089 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 HW: 4E0 907 468 A Component: Gateway H06 0040 Revision: 06 Serial number: 0000302B2915AF Coding: FCFE7BDC2B3504 Shop #: WSC 00000 000 00289 VCID: E5C1D71F2C949D36875-80B0 1 Fault Found: 01327 - Control Module for Parking Aid (J446) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 6 Reset counter: 74 Mileage: 164723 km Time Indication: 0 Date: 2015.05.08 Time: 18:30:30 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 Component: CD-Changer H43 0470 Revision: 00000501 Serial number: AUZ5ZBB1007573 Shop #: WSC 00000 000 00000 VCID: 1C3732FBDF5E1CFE68B-8049 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H01 0070 Revision: 00703201 Serial number: AUX3Z0BD106427 Coding: 0264192 Shop #: WSC 02311 785 00200 VCID: D8BFEEEB6BE630DE0C3-808D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 1 Fault Found: 00172 - Key 2 not learned 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 5 Fault Frequency: 2 Reset counter: 50 Mileage: 164176 km Time Indication: 0 Date: 2015.04.24 Time: 12:07:58 ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 C HW: 4E0 907 553 C Component: LUFTFDR.-CDC H03 4190 Coding: 0015500 Shop #: WSC 02313 785 00200 VCID: 23450907E2202306A91-8076 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 B HW: 4E0 959 760 Component: Sitzmemory FS H05 0020 Revision: 00000000 Serial number: 5DS 008 795-02 Coding: 3670018 Shop #: WSC 02311 785 00200 VCID: 224B0C03FD3A2A0EA27-8077 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 M Component: MNS ECE H51 1060 Revision: 00000000 Serial number: 364BX087760684 Shop #: WSC 00477 128 65295 VCID: 3B75D1677A907BC6811-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H01 0060 Serial number: 00000232200124 Coding: 0035856 Shop #: WSC 02312 785 00200 VCID: 1D313FFFC44415F69F5-8048 4 Faults Found: 01370 - Alarm triggered by Interior Monitoring 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 4 Reset counter: 50 Mileage: 162608 km Time Indication: 0 Date: 2015.03.12 Time: 16:54:00 Freeze Frame: Bin. Bits: 00000000 02160 - Lamp in Sunroof Switch (L65) 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 0 Fault Frequency: 15 Reset counter: 75 Mileage: 164672 km Time Indication: 0 Date: 2015.05.08 Time: 07:48:00 00212 - Control Circuit for Reading Lights Front Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 230 Mileage: 0 km Time Indication: 0 Date: 2015.03.31 Time: 17:03:00 00213 - Control Circuit for Reading Lights Front Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 230 Mileage: 0 km Time Indication: 0 Date: 2015.03.31 Time: 17:03:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 HW: 4E2 959 801 Component: Türsteuer.FS BRM004 0060 Coding: 0026914 Shop #: WSC 02311 785 00200 VCID: DEB3F8F309C2CEEE46F-808B 1 Fault Found: 02110 - Window Regulator Switch 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 66 Mileage: 164528 km Time Indication: 0 Date: 2015.05.05 Time: 07:55:42 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 HW: 4E0 907 289 Component: Komfortgeraet H02 0050 Coding: 0000729 Shop #: WSC 02311 785 00200 VCID: E6C3D013D192962E8EF-80B3 Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H01 0020 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 35 Mileage: 115528 km Time Indication: 0 Date: 2012.11.18 Time: 13:47:17 Freeze Frame: Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 P HW: 4E0 035 223 A Component: DSP-Amp.-High H12 0460 Revision: PROD_01O Serial number: 00000000055584 Coding: 0000017 Shop #: WSC 02313 785 00200 VCID: 2A5BE423850AF24EEA7-807F 1 Fault Found: 02084 - Component Protection 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 162 Mileage: 161852 km Time Indication: 0 Date: 2015.02.21 Time: 15:17:38 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 HW: 4E0 907 280 A Component: ILM Beifahrer H06 0050 Revision: Serial number: 00000000006974 Coding: 0010101 Shop #: WSC 59152 001 1048576 VCID: DDB1FFFF04C4D5F65F5-8088 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 HW: 4E2 959 802 Component: Türsteuer.BF BRM004 0060 Coding: 0026914 Shop #: WSC 02311 785 00200 VCID: DEB3F8F309C2CEEE46F-808B No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 A HW: 4E0 907 801 Component: EPB AV1C1010 H01 1010 Revision: AV1C1010 Coding: 0000331 Shop #: WSC 00011 888 96745 VCID: 1D313FFFC44415F69F5-8048 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0030 Revision: 00000001 Serial number: Coding: 0000001 Shop #: WSC 02311 785 00200 VCID: E2CBCC033DBAEA0E627-80B7 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 Component: TUNER EU/US/RDW H41 0630 Revision: 00000000 Serial number: 304LQ027511595 Coding: 0000001 Shop #: WSC 02312 785 00200 VCID: 3169F34FA8DC81962BD-8064 1 Fault Found: 00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 253 Mileage: 145715 km Time Indication: 0 Date: 2014.07.31 Time: 10:59:05 ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: 4E0-910-146.clb Part No SW: 4E0 910 146 G HW: 4E0 919 146 Component: TV analog TUNER H11 0300 Revision: 00000006 Serial number: 00000000000000 Coding: 0001003 Shop #: WSC 02313 785 00200 VCID: 2541171FEC14DD36C75-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: ENERGIEMANAGER H12 0480 Revision: 00000000 Serial number: 00000000011440 Shop #: WSC 00000 000 00000 VCID: 204F060BF336381EB43-8075 Subsystem 1 - Part No: 000 915 105 AK Component: von VA0 1211280464 Coding: 303030393135313035414B56413031323131323830343634 Shop #: WSC 00185 210 88124 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 801 A Component: Türsteuer.HL BRM004 0060 Coding: 0026914 Shop #: WSC 02311 785 00200 VCID: DDB1FFFF04C4D5F65F5-8088 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 802 A Component: Türsteuer.HR BRM004 0060 Coding: 0026914 Shop #: WSC 02311 785 00200 VCID: DDB1FFFF04C4D5F65F5-8088 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0030 Revision: 00H12000 Serial number: 08720528501085 Coding: 0201108 Shop #: WSC 02313 785 00200 VCID: 23450907E2202306A91-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 M HW: 4E0 862 335 Component: Handyvorb2 H18 1130 Revision: 00000000 Serial number: 00000005070940 Coding: 0010920 Shop #: WSC 00000 000 00000 VCID: 2C57E23B8FFEEC7E18B-8079 No fault code found. End --------------------------------------------------------------------- |
Sorted it.
Had to update MMI Control Unit module 07 adaptation channel 1 to add the front acoustic parking sensors and rear acoustic parking sensors. I hadn't considered doing this because the acoustic side of the system was working fine. Anyway, after adding bits 2 and 3 (12) to the original value I then got the optical parking aid displayed on the MMI screen - well after another MMI reset I did. Thanks for the help guys. Hope this helps someone else too. |
I think you need to go into the MMI menu on the car rather in VCDS to enable the display. I think its is the car..systems menu
2004 A8 3.0 TDI Sport Brilliant Black - now gone |
Just fitted one of these C boxes and it worked straight off. Am guessing that the car may have had one fitted before and someone cheapskated or sold the upgrade seperately!
Nice and useful upgrade for me as I have to park the car next to a wall where other cars are also parked, which means an acoustic sensor is full on and you have to guess distance! Lee |
Tags |
optical, parkhilfe, parking sensors, pdc |
