Hi all,
I'm hoping that someone out there has had experience of this issue and found a way to overcome it. I have been experiencing an intermittent ESP warning for a few months now which is really bugging me. Sometimes the warning will flash 3 times and disappear for the rest of the journey other times it will illuminate and stay on for my entire journey. I have once managed to quickly scan it and catch the code which can be seen below in the ABS section: Sunday,20,September,2015,16:37:53:07419 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 15.7.1.0 Data version: 20150904 www.Ross-Tech License Plate: Mileage: 146370km-90950mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0F 11 31 15 16 17 18 19 1E 25 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 67 72 76 77 Mileage: 146370km-90950miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Sporadic communication error 1000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: Sporadic communication error 1000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI G000AGMª0070 Revision: --H01--- Serial number: AUX3Z0E9376803 Coding: 0011773 Shop #: WSC 00783 210 84012 VCID: 224BBD6DFDD30A2E6B-8076 2 Faults Found: 000408 - Engine Oil Temp. Sensor (G8) P0198 - 000 - Signal too High - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 4 Reset counter: 255 Mileage: 146189 km Time Indication: 0 Date: 2015.09.18 Time: 11:07:11 Freeze Frame: RPM: 1155 /min Torque: 237.9 Nm Speed: 4.7 km/h Duty Cycle: 31.6 % Voltage: 14.36 V Temperature: 21.6°C Temperature: 79.2°C 005715 - Please check DTC Memory of ABS Controller P1653 - 002 - - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 146190 km Time Indication: 0 Date: 2015.09.18 Time: 11:08:07 Freeze Frame: RPM: 1428 /min Torque: 183.3 Nm Speed: 40.1 km/h Duty Cycle: 25.6 % Voltage: 14.44 V Bin. Bits: 00101000 Torque: 230.1 Nm Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 P HW: 09E 927 156 B Component: AG6 09E 4,2lTDI RdW 0030 Revision: --H01--- Serial number: 0070556 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 306F4725A33FA8BEED-8064 1 Fault Found: 009783 - Torque Management Feedback Signal A P2637 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 3 Reset counter: 40 Mileage: 146189 km Time Indication: 0 Date: 2015.09.18 Time: 11:07:14 Freeze Frame: RPM: 1408 /min RPM: 864 /min RPM: 352 /min (no units): 8.0 (no units): 54.0 Temperature: 59.0°C T.B. Angle: 30.2° ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0008557 Shop #: WSC 02313 000 00000 VCID: 224BBD6DFDD30A2E6B-8076 1 Fault Found: 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H08 0160 Revision: 01604808 Serial number: AUX3Z0E9376803 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BFDF85EB0F90FE45-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 1 Fault Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 0 Reset counter: 11 Mileage: 146144 km Time Indication: 0 Date: 2015.09.17 Time: 17:07:54 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H01 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 00000 785 00200 VCID: 2447BB75E7C7041E19-8070 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 730 Q HW: 4E0 035 729 A Component: Interfacebox H43 2120 Revision: 00000000 Serial number: 300JK057560615 Coding: 0000002 Shop #: WSC 00000 785 00200 VCID: 2E53595DB90BBE4EFF-807A Subsystem 1 - Part No: 4E0 910 609 C Component: Bedienteil MMI H42 0100 Subsystem 2 - Serial number: 318J.057516748 Subsystem 3 - Serial number: 7426.10.0500000000218B0164ÿ Subsystem 4 - Serial number: 8B0164ÿ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 D Component: KLIMAAUTOMAT 016 0400 Revision: 00000030 Serial number: 00000000078944 Coding: 1136657 Shop #: WSC 02311 785 00200 VCID: 1C378395DFB73CDEA1-8048 2 Faults Found: 00065 - Rear Left Footwell Heater (Z42) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 226 Mileage: 146156 km Time Indication: 0 Date: 2015.09.17 Time: 15:00:06 Freeze Frame: Voltage: 11.40 V 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 226 Mileage: 146156 km Time Indication: 0 Date: 2015.09.17 Time: 15:00:06 Freeze Frame: Voltage: 11.40 V ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 L HW: 4E0 907 279 L Component: ILM Fahrer H13 0210 Coding: 0143121 Shop #: WSC 02313 785 00200 VCID: 31694221A835A1B6E2-8064 Subsystem 1 - Part No: 4E2 910 113 B Component: Wischer WWS D3 H50 0420 Coding: 00000037 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0050 Coding: 00139548 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: None Part No SW: 4E0 910 563 B HW: 4E0 035 563 Component: DAB-Tuner H41 0700 Revision: 00000001 Serial number: KE1229T7900209 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2345B869E2C9032660-8076 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI G000AGSª0070 Revision: --H01--- Serial number: AUX3Z0E9376803 Coding: 0011773 Shop #: WSC 00783 210 84012 VCID: 224BBD6DFDD30A2E6B-8076 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H12 3610 Revision: 91H12360 Serial number: 0037P000848C Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 275DAC7996F1EF063C-8072 Subsystem 1 - Serial number: 63328RB400BD74DF+ Subsystem 2 - Serial number: 63428RB400BD74D3U Subsystem 3 - Serial number: 63528RB400BD74A2R Subsystem 4 - Serial number: 63628RB400BD7547S Subsystem 5 - Serial number: 63729RB400BE4C47Z Subsystem 6 - Serial number: 63829RB400BE5A32T No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112141 Shop #: WSC 02313 785 00200 VCID: 65C1E671AC7D3D16CE-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 P HW: 4E0 920 950 P Component: KOMBIINSTR. VDO H71 0400 Revision: D02 Serial number: AUDID3EN000475 Coding: 0000413 Shop #: WSC 34263 001 1048576 VCID: 31694221A835A1B6E2-8064 1 Fault Found: 00562 - Sensor for Oil Level/Temperature (G266) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 14 Mileage: 146190 km Time Indication: 0 Date: 2015.09.18 Time: 11:08:09 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 E Component: Heizgeraet H07 0110 Revision: 0000000C Serial number: 00000009006406 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 1A3B858DD58342EEB3-804E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 B HW: 4E0 907 468 E Component: Gateway H11 0090 Revision: 11 Serial number: 2000305A2180CA Coding: FCFEFFDE2B7D04 Shop #: WSC 02313 785 00200 VCID: 275DAC7996F1EF063C-8072 2 Faults Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 13 Mileage: 146156 km Time Indication: 0 Date: 2015.09.17 Time: 17:04:47 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 13 Mileage: 146156 km Time Indication: 0 Date: 2015.09.17 Time: 17:04:47 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBE8004211 Shop #: WSC 00000 000 00000 VCID: 1C378395DFB73CDEA1-8048 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H08 0160 Revision: 01604808 Serial number: AUX3Z0E9376803 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BFDF85EB0F90FE45-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 1 Fault Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 0 Reset counter: 11 Mileage: 146144 km Time Indication: 0 Date: 2015.09.17 Time: 17:07:54 ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 A Component: KLIMA-STG. FOND 015 0220 Revision: 00000018 Serial number: 00000000033564 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 61C9F261B855513632-8034 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 285FAF459BEFE07E35-807C No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H01 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063338 Shop #: WSC 00000 785 00200 VCID: 2447BB75E7C7041E19-8070 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D Component: MNS ECE H46 0850 Revision: 00000000 Serial number: 364JR057501185 Shop #: WSC 00000 785 00200 VCID: 3B7560097A795BE648-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H02 0090 Serial number: 00000528000092 Coding: 0035972 Shop #: WSC 02313 785 00200 VCID: 1D318E91C4AD35D656-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 B Component: Türsteuer.FS BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 204FB765F3DF183E7D-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 B HW: 4E0 907 289 Component: Komfortgeraet H05 0010 Revision: 00100005 Serial number: W040511020220 Coding: 0004317 Shop #: WSC 02313 785 00200 VCID: 285FAF459BEFE07E35-807C Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H04 0020 1 Fault Found: 00892 - Switch for Trunk Closing Cylinder (F248) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 41 Reset counter: 17 Mileage: 146192 km Time Indication: 0 Date: 2015.09.18 Time: 11:23:55 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 N HW: 4E0 035 223 E Component: DSP-High D3 H02 0050 Revision: PROD_01 Serial number: 00000000778000 Coding: 0000023 Shop #: WSC 02313 785 00200 VCID: 285FAF459BEFE07E35-807C No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000072415 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E33899DC9AB2ECE4F-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 B Component: Türsteuer.BF BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 204FB765F3DF183E7D-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0001031 Shop #: WSC 00762 210 91493 VCID: 1F4DB499CEA127C644-804A No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 F Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000006 Shop #: WSC 02313 785 00200 VCID: 3D716E11646D55D676-8068 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 L HW: 4E0 035 541 L Component: TUNER EU/US/RDW H42 0560 Revision: 00000000 Serial number: 304JQ057610774 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2959AA4180E5D9762A-807C No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: 4E0-910-146.clb Part No SW: 4E0 910 146 E HW: 4E0 919 146 C Component: TV analog TUNER H14 0270 Revision: 00000040 Serial number: 00000000021122 Coding: 0000003 Shop #: WSC 00000 785 00200 VCID: 2345B869E2C9032660-8076 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000004689 Shop #: WSC 00654 210 60455 VCID: 204FB765F3DF183E7D-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 1234567890 Coding: 344530393135313035412056413031323334353637383930 Shop #: WSC 00762 210 89838 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 1E33899DC9AB2ECE4F-804A No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 K HW: 4E0 035 753 A Component: SDS 3502 UK H45 0600 Revision: 00000000 Serial number: 00000510130360 Shop #: WSC 12336 024 394758 VCID: 2E53595DB90BBE4EFF-807A No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 1E33899DC9AB2ECE4F-804A 1 Fault Found: 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 14 Reset counter: 233 Mileage: 146144 km Time Indication: 0 Date: 2015.09.17 Time: 15:00:04 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0030 Revision: 00H12000 Serial number: 08720529302617 Coding: 0201108 Shop #: WSC 02313 785 00200 VCID: 2345B869E2C9032660-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 F HW: 4E0 862 335 Component: Handyvorb2 H13 0580 Revision: 00000000 Serial number: 00000007588199 Coding: 0010900 Shop #: WSC 02313 785 00200 VCID: 2541A671ECFDFD160E-8070 No fault code found. End-------------------------(Elapsed Time: 04:02)-------------------------- I am hoping that the oil temp sensor is throwing up the error and I will get this addressed. Thank you in advance for any suggestions/experiences as it will discourage me from playing part swap roulette hoping to fix it! I have searched high and low for an answer but solutions on other vehicles vary and some D3 experience would be great. Many Thanks, Scott |
There is no logical connection between oil temp sensor and ESP light. It's to do with:
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 17th January 2016 at 05:44 AM. |
Mmmmmm , engine torque signal may be reduced due to engine thinking engine oil temp is to high .... it's defaulted to a safer map as safe guard
Gearbox ecu will pick up on this on the network from engine and pass fault over to abs / traction Very often any engine management issue the traction and cruise control will be disabled Jag xf diesels have similar issue but other way round , gearbox oil temp sensor shows oil temp to high and defaults engine to a safer map ... not full limp though but you can feel some power loss , cruise and traction get disabled also Not 100% with the Audi but could be a possibility |
Thanks for the replies gents, makes sense now.
I haven't experienced any loss of power or disabled cruise control though! So if I'm looking at the MAF's or TB's is there any logging I can do or tests I can perform to isolate the part at fault? I can clear the fault codes but they return so does it require any type of dealer reset that my full copy of VCDS cannot do? Reset the throttle bodies if that'll help. |
My first port of call would be to get rid of that oil overheat code , I would of thought that the engine and gearbox program will not like to see that code
The date and time stamp are quite a few months back is this a report from a while back ??
I will clear all codes and take a drive so that you can see the reoccurring codes |
Sunday,13,March,2016,18:54:57:07419
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 15.7.4.1 Data version: 20160216 www.Ross-Tech.com Mileage: 166180km-103259mi Repair Order: ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI G000AGMª0070 Revision: --H01--- Serial number: AUX3Z0E9376803 Coding: 0011773 Shop #: WSC 00783 210 84012 VCID: 224BBD6DFDD30A2E48-8076 2 Faults Found: 000408 - Engine Oil Temp. Sensor (G8) P0198 - 000 - Signal too High - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 8 Reset counter: 255 Mileage: 166167 km Time Indication: 0 Date: 2016.03.13 Time: 17:51:58 Freeze Frame: RPM: 1428 /min Torque: 89.7 Nm Speed: 55.5 km/h Duty Cycle: 18.1 % Voltage: 14.36 V Temperature: 9.0°C Temperature: 70.2°C 005715 - Please check DTC Memory of ABS Controller P1653 - 002 - - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 166172 km Time Indication: 0 Date: 2016.03.13 Time: 17:57:44 Freeze Frame: RPM: 1176 /min Torque: 3.9 Nm Speed: 48.4 km/h Duty Cycle: 0.4 % Voltage: 14.44 V Bin. Bits: 00101011 Torque: 440.7 Nm Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 P HW: 09E 927 156 B Component: AG6 09E 4,2lTDI RdW 0030 Revision: --H01--- Serial number: 0070556 Coding: 0001001 Shop #: WSC 02313 785 00200 VCID: 306F4725A33FA8BECE-8064 1 Fault Found: 009783 - Torque Management Feedback Signal A P2637 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 3 Reset counter: 40 Mileage: 166167 km Time Indication: 0 Date: 2016.03.13 Time: 17:52:01 Freeze Frame: RPM: 1472 /min RPM: 1440 /min RPM: 1280 /min (no units): 36.0 (no units): 27.0 Temperature: 60.0°C T.B. Angle: 17.6° ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0008557 Shop #: WSC 02313 000 00000 VCID: 224BBD6DFDD30A2E48-8076 2 Faults Found: 00003 - Control Module 014 - Defective 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 2 Faults Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 14 Reset counter: 109 Mileage: 159808 km Time Indication: 0 Date: 2016.01.19 Time: 05:06:26 00166 - Access/Start Authorization Switch (E415) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 0 Reset counter: 56 Time Indication: 0 ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 285FAF459BEFE07E16-807C 1 Fault Found: 01772 - Signal from Level Control Pressure Sensor (G291) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 37 Reset counter: 112 Mileage: 159955 km Time Indication: 0 Date: 2016.01.20 Time: 05:02:27 ------------------------------------------------------------------------------- Any thoughts on possible fixes? The light is still very intermittent, seems to be increased frequency in wet conditions. Thanks again |
Im still suspicious of the engine oil temp signal , just think that the engines running stratagy could limit torque because it thinks engine oil is to hot and plays it safe , gearbox and abs ecms see the signal and log codes to do with load signals.
Is the oil temp signal in the level sensor in the sump ? |
In the meantime to rule out the earlier suggestion of MAF or TB faults is there any logging I can do to ensure they're running as expected? Thanks |
