Long story short. Today for the first time ever I had that pit of the stomach feeling about owning the d2 s8> As I went to leave a car part the car revved loudly and stayed put. No drive at all. I tried the shifter in various positions, went to tiptronic and was about to weep loudly when with a large clunk something engaged and the car moved again.
The lack of acceleration was accompanied by all of the gear selector lights on the dash illuminated together. Clearly the car was locked in to some form of limp mode. HAd the codes read properly this evening and , despite the lovely lady at A8 parts doing a good luck jig down the phone for me that we threw up a f125 code we got the dreaded PO730 Gear:Incorrect ratio Now, is this a coincidence or a possible help? For the past 2 days the auto dip reverse mirror had started to work, for the first time in a years ownership, although it then stayed in the dipped / curb position when engaging drive and also the steering wheel had started to electronically adjust / move when I opened the drivers door. Is this all unrelated or helpful in diagnosing why the greatest all round car I have always promised myself is sat outside and I have the urge to beat it with any branch to hand Basil Fawlty style... Any serious help or suggestions welcomed. And yes, I have Googled and spoken to our sponsors and had the codes read properly so I'm looking to move forward from there please. Thanks as always
Usually huffing, puffing and buffing in a dark corner somewhere... |
I feel for you. Just gone thru similar but mine indicates the F125. Did you check Rosstech Wiki? Not that it give smuch hope beyond what you already know.
2002 D2 S8 – Ming Blue, Valcona leather, Vavona wood insert, solar sunroof (to be fitted), Heated rear seats, extended leather pack, 18” Avus, ski hatch, Bose, auto dim rear view mirror, rear blind. Last edited by David's8; 18th October 2016 at 08:19 PM. |
Could it be a damp problem, have you checked that the scuttle drains are all clear and not full of water or showing signs of water having been present. We've had a lot of rain recently so maybe thats the problem. The gearbox ECU and other electronics modules are under that cover on the passenger side, maybe remove the cover and look inside for water.
Also check the area down in the passenger footwell for damp, typically caused by "Botangs Hole" or possibly blocked A/C drains.
My experience of dipping mirrors on reverse is that they are (or become) close to random in operation. ![]()
Spoken to the great fella at Mackies. (0141) 778 4545
May help others treading the same path? Ok, put simply the p0730 code relates to gearbox slippage. The ECUs are telling one another that the engine speed and gearbox speed are not within expected parameters. Unless the code reader was saying specifically the f125 fault, then checking it or playing around with it is a worthless task. So, slippage. Can be electrical or mechanical failing. The box was, reputedly, a sealed for life affair. There isn't, as we know, a dip stick or more traditional level indicator on the box. So, look for evidence of leaking transmission fluid underneath. IF you find some then this may be better news! To investigate the box has 2 plugs on it 1. Lower - sump drain plug 2. Higher up - An all but hidden top up plug. This top up plug needs a length of plastic tube fabricating to it to top up the oil level until the oil is pouring back at you down the tube. They assure me this is the only true indicator that the box has the recommended levels of fluid in it. Clear the codes and see if this improves matters any. If there are no signs of leaks (and like the desperate child I am you still want a mechanic to try topping up the fluid "just in case" ) then the slippage is within the box itself and arguably terminal . A current reconditioning is £2942 + vat As you were chaps...
Hi,
I had that code, (incorrect gear ratio) which was due to low gearbox oil level. The reason for the low oil level was a leak from the sump. Whoever did the oil and filter change prior to my ownership, had not tightened the sump bolts correctly, so the leak was from there. My mechanic only got 5 liters of oil out. It should hold 8. Also the filter had a 2 inch split in it, which would not have helped either. New filter, 8 liters of oil and a new sump gasket solved the problem. Gearbox works a treat now. Good Luck David
2002 S8 Final Edition, Avus Silver with Red leather interior Guildford, Surrey Tiptronic with Sport mode button. Sony rear entertainment package. Bose sound system. Audi Navigation Plus. 20 inch Final Edition alloys Full Cat Back Stainless Milltek exhaust, giving a great V8 burble ![]() ![]() 1997 A8 Quattro Sport - Now sold when S8 FE purchased ![]() |
As much as we all feel for you when this happens and would truly wish you all the luck in the world for a simple fix, the big "clunk" you describe is telling for something in the gearbox breaking.
You should definitely check all the usual things like fluid, sump damage, filter pick up clearance etc... I too recently had gearbox issues with an extraordinary stroke of luck when a cracked feed pipe for one of the clutch packs was found to be the cause of my issues. However my gearbox never "clunked" into Drive (it did give a couple of shifting thumps) and gave flaring/slipping gear changes under moderate throttle inputs indicative of low fluid (which is why I checked it twice!) before failing into limp mode. One thing my transmission specialist did say about the 5HP24, particularly in RWD guise in Jags, Beemers and Range Rovers, is that the Valve Body housings crack. Quite what symptoms this will produce, I couldn't tell you. However, it's cheaper than a whole gearbox! Good luck!
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived ![]() Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) Last edited by 27litres; 20th October 2016 at 10:47 AM. |
Advanced transmissions in Billingham (as recommended on here ) offered these thoughts...
The huge clunk will invariably be the front drum cracked inside the box. Apparently its a classic tell tale when in limp mode. He doesn't see a lot of gains topping up fluids etc as , having done "20 -30 of these boxes when most people wont touch them" that is where the finger of fate is pointing. Very helpful chap. Did also give me a heads up that the manifiold bolts can also prove problematic as part of this whole repair. Our site sponsors will pay £500 for the car as it stands as a breaker. I had just advertised it for sale for £3200 (its Ollies old car if that makes any difference to people knowing how meticulously it had been cared for - including gearbox oil changes...) £2942 + vat for reconditioned box = £3530.50 Ho hum .... ![]()
Usually huffing, puffing and buffing in a dark corner somewhere... Last edited by Bushido; 20th October 2016 at 11:27 AM. |
Usually huffing, puffing and buffing in a dark corner somewhere... Last edited by Bushido; 20th October 2016 at 11:26 AM. |
£500 isn't a bad no nonsense offer in fairness. I cant see a D2 with a faulty gearbox getting much more than that on the likes of ebay these days and that would be accompanied by all the usual time wasters you have to fend off. Whilst demand for sound low mileage S8's has gone up, the demand for non runners and spare parts is very much in decline unfortunately. Ironically, the gearbox is about the only part of my car that hasn't caused me any concern as yet (touch wood) ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
