Old 13th November 2016, 01:52 PM
milenajdoski milenajdoski is offline
Default No abs or esp light at all
When you engage contact everything lights up and says OK only abs light and triangle for esp.those 2 wont light at all.
So i accessed the unit with vag and ut gives 2 codes.
One 00301 abs return pump (which i will repair next weekend) and 001486 which can be sorted after the first error is removed.
But i am confused
Why no beeps or abs and esp errors on start or while driving???
Definately no abs or esp works(tires slip on start and no abs when braking)
Also when i press the esp disable button in the dash nothing happenes.
So any ideas?
Photos of the errors in atach
Maybee some coding issue???
https://postimg.org/image/4em7hzgvz/
https://postimg.org/image/x4wkigusz/
Can someone please check how this looks in his car??
Mine is d2 2001 2.5 tdi 132kw facelift 6speed manual transmision withouth quattro and with esp
